Re: Big 3 conversion
I am sure folks have done this before on here probably just a different name.
I used 4 gauge wire, but the bigger the gauge the better.
It consist of running 3 wires.
- 1 from the alternator to the battery positive of the battery post
- 1 from the negative side of the battery to a ground, frame preferred but you can go to the body.
- 1 from the engine to the frame
It basically reduces the resistance in your electrical system and is kinda must when running any form of stereo or in most cases and mine, electric fans, electric water pump and I know my shurflo pump draws alot as well and so on.
I did it for about 30 dollars at autozone using 2 battery post extenders and the wire I used pre made new battery cables since they already have the ring connectors on there, are color coded and I felt I only needed 4 gauge wire.
Like I said I was skeptical about it but am doing this to all my car regardless now.
If you need any help let me know or if you know what else it is called that would be good info
