You'll need a chip. Theoretically speaking, if you ran 50# injectors on a 25# chip, you'd be dumping in twice as much fuel as you should (since 50#ers flow twice as much as 25#ers). However, it's not a flat 25# or 50# across the whole range. At WOT, the 50#ers probably flow twice as much as 25#ers. At idle though, they might only flow 10% more (random numbers picked for comparison). The fueling values in the chip have to take into account the properties of the specific injector. You can use fuel pressure somewhat to control fueling after switching to a bigger injector, but it won't run its best unless the chip is made for the injectors.
That said, the Ultimate comes in variations for stock or 50# injectors. The 50# Ultimate is also tweaked for some other mods as well, I believe. You'll probably want to stick to stockers if you don't plan on big mods, or plan on 50#ers if you're going for a big build, unless you want to do your own tuning and chip burning (or pay someone else to).
