Bin patch file to improve TunerPro ALDL connectivity.
turbodig
The link below is a patch file to fix some receive setup problems in the $58 code.
This seems to fix Moates Autoprom connectivity in Emulation mode on the vehicles that it's been tested on so far.
It also makes Tunerpro in general connect a lot better/faster, even with a regular cable.
To patch, you'll need to have patcher from:
http://www.digwaretech.com
Follow the Bin Patcher menu.
From there, just patch your Syty bin with the txt file at the link below.
This should work with all the released wide-band patches that I've done, but I can't guarantee how well it'll work with someone else's.
This also won't work with my early Syty extended F77 patch, so if you're running that, you'll need to remove that patch first.
You can get this patch at:
http://digware.lunarpages.com/digware/aldlpatch.zip.
This patch is freely available to anyone who wants to use it. As with any code patch, stuff can go wrong. This is a very early beta patch, and has only been tested on a few applications.
Usual disclaimers apply:
User assumes all risk! Allow 4-6 weeks for delivery! Do not taunt Happy Fun Ball! Do not take internally!
Later,
skwayb
NWSTP
Re: Bin patch file to improve TunerPro ALDL connectivity.
I helped initially test this patch and it is awesome. It makes it so you can finally use your AUTOPROM in TunerPro to emulate and log at the same time in $58. Also it makes it connect very quickly in both TunerPro and Datamaster.
In Datamaster the waiting PCM sync only shows up briefly. No more sitting there waiting for it to connect up for a couple of seconds. It just connects asap.
I haven't tested this on EFILIVE so not sure if it works with it.
Thanks Dig for making this patch.
Wikid 1
200+ lbs of puppy!
umm okay. maybe i'm not understanding this. I'm hitting run, then running the patcher, but all i get is a small window that says; SyTy patcher by Dig Usage- patcher.exe <binfile><patchfile> and i hit the okay and it dissapears... :dunno:
MRKING
New Parts for Old Trucks
"Command syntax is as follows: (assuming you extracted the files to c:patcher)
patcher c:mybindirmychipbin.bin c:patcherptchfile.txt
This will apply the patch contained in ptchfile.txt to mychipbin.bin, and will output the results to mychipbin.bin.pch "
Then change the file extension on mychipbin.bin.pch to mychipbin.bin and upload to chip/emulator .
Ian Turgeon
Cascading Inspiration
I feel like I owe people beers. I heart you guys.
turbodig
SyTyArchives said:
I heart you guys.
That's right up Jeff's alley.
Better bring wine coolers for him...
later,
later,
Jeremy said exclusivly after my weekend with his wife I can't snuggle in bed next to him. Got a spare room key dig?
turbodig
Sorry. Fresh out.
sytyguy
Moderated User
Hey now, if code59 is slang for a gay switcheroo, then I'll hafta go back to $58. Crap, I've had this gay code in my truck for weeks now, no telling how my truck has been influenced. Pretty soon, the truck will only go in reverse with the tailgate down.
:barf:
Hood
I am beleiver that your born gay. No amount of gay porn & influences is going to rewire my desires.
I think your truck will be all set, unless ofcourse you notice that your truck has propensity to back up & shove varies item into its exhaust.
ashman
yeah, i met Jeff this past weekend, with a bunch of GUYS at Hooters. All we talked about was trucks!!! The waitresses were rubb'n dem BooBies all over us and no one said a word. :)
sytyguy
Moderated User
Don't get me started on that subject. My Christian beliefs shine through in that matter, and I have a stern opinion on that subject.
Anywho, back to the lighter side of things. I've already casterated my exhaust @ the DP, so no chance of anything being inserted rearward. But, I did notice that my lumbar self inflated this morning, and it seemed to be much more snug around the azz area. Hmmmm......
Might hafta buy a Typhoon (that's the female version of these trucks for those of your that dont know - better looking rear, softer skin, etc...) to get my truck back on my side of the fence.
Hood
Hood
I always thought the syclone was the female version since it has a bigger trunk.
sytyguy
Moderated User
True, but you can't put anything in it. So, it's a guy. :D
Hood
2kwik4u
Resident slow guy
I've seen Jeff's Syclone have a "trunk" full of stuff on several occasions......
I think I need to keep my trucks the hell away from him for awhile!!!
Seeing how your red truck hasn't seen anything more than jackstands that should be a problem.
And your other truck looks something like
2kwik4u
Resident slow guy
Just had a phone conversation with Jeff.....Went something like this;
Me: ring ring
Jeff: Hi this is Jeff
Me: Can I speak to pot please, this is Kettle speaking
Jeff: You bastage
:D :D
At least my bus is yellow, your's is a crappy dark green color :D
Tooky
Serious about performance
Whoa! Where did this slip between the cracks? I can't believe I've never seen this. So you just patch your BINs and the only thing it changes is that the ALDL will link up faster? Sounds great to me! :D
Any caveats? I run standard Ultimate 3 Bar $58 BINs patched for PLXLinear WBO2 datalogging in the "AFR Target" and "EGR DC" fields in DataMaster. Anything I need to be aware of? I guess I'm not 100% sure exactly what this patch changes in the chip.
Thanks!
ashman
no caveats...
you, of all people, should make the move to $59
turbodig
Thanks!
It fixes a bug in the ALDL receive routine. This is pretty much the only way Tunerpro will connect to an Autoprom. Or anything else for that matter.
I'd apply the ALDL patch, then re-apply your PLX patch. It really shouldn't matter as far as order goes, I've just done it this way, and I know it works.
Later,
