so what is the most power the stock block can take safely?skata said:well i dont know about 1000 hp, but bowtie blocks are pretty strong.
i'd be more worried about the crank first.
i'd say stock block internals could do 12's safely.
11's would be pushin it, and tenskeep your fingers crossed.
the stock block can go a long way. the other stock internals will break before the block. the most common failures are broken cranks, bent rods, and piston failure.AXAdamm said:so what is the most power the stock block can take safely?
Pittman said:The above is very true. A stock block with good internals like a billet crank, oliver rods etc. Could really get it on. The bowties have a little more meat between the cylinders so you can go over 300ci with them. The bowties also have more meterial around the main cap area.
ALTHOUGH, the only blocks I have ever seen destroyed have been bowties. There was picture on here of one that had the main caps literaly pushed out. AND there is a local truck here in dallas pushing a load nitrous on a late model s-10 and his block cracked in the exact same place both were bowties.
I guess there would be a moral to the story.
