Every few weeks I am posting about the problem I have building boost. If I set the Ultimate to 17 or 18 psi it only make about 15 psi in 1st and 2nd gear. I was told that my WG spring might be weak. Yesterday I unplugged the boost seleniod to check base boost. My WG rod is very tight, only 3 threads left. It made 15 psi in 1st and I let off. Same in 2nd. Does this mean my WG spring is in good shape? Did I check it correctly?
