Maxtor
My boost is out of control - it swings up and down resembling a sine wave pattern at WOT in 3rd/4th gear - with the ultimate 18psi setting it varies between 15.8 and 19 continuously. It has a stock boost control system with an ultimate chip - Borla cat back exhaust WITH a stock cat in place. 20g turbo with 12cm2 turbine.
What I have tried:
Swapped boost solenoid with known good one.
Swapped actuator with known good one.
Replaced all vac. lines with silicone 2x; ensured all are tight.
Replaced ultimate carrier with new one (thought old one may have bad connection).
Verified boost control ckt. 903 for 12v with key on.
Verified ckt. 471 for continuity between the plug at the solenoid and the computer plug.
Adjusted the WG rod SEVERAL times.
WG moves freely.
Datamaster shows correct boost target. WG duty cycle seems to react to boost pattern - so I assume it is trying to correct boost as it rides up and down.
TPS volts are above 3.8, TPS% is 100.
I put the stock chip in w/2-bar MAP – boost is better but still fluctuates.
I am REALLY starting to get frustrated. Can anyone give me another idea? The only thing I can think to do now is hard wire ckt. 903 to 12v and/or re-wire ckt. 471 with a new wire.
OR is a 3 psi swing the best I can hope for with the stock WG at WOT in 3rd/4th gear?
What I have tried:
WG moves freely.
