Boost control - ideas (long)?
Maxtor
My boost is out of control - it swings up and down resembling a sine wave pattern at WOT in 3rd/4th gear - with the ultimate 18psi setting it varies between 15.8 and 19 continuously. It has a stock boost control system with an ultimate chip - Borla cat back exhaust WITH a stock cat in place. 20g turbo with 12cm2 turbine.
What I have tried:
Swapped boost solenoid with known good one.
Swapped actuator with known good one.
Replaced all vac. lines with silicone 2x; ensured all are tight.
Replaced ultimate carrier with new one (thought old one may have bad connection).
Verified boost control ckt. 903 for 12v with key on.
Verified ckt. 471 for continuity between the plug at the solenoid and the computer plug.
Adjusted the WG rod SEVERAL times.
WG moves freely.
Datamaster shows correct boost target. WG duty cycle seems to react to boost pattern - so I assume it is trying to correct boost as it rides up and down.
TPS volts are above 3.8, TPS% is 100.
I put the stock chip in w/2-bar MAP – boost is better but still fluctuates.
I am REALLY starting to get frustrated. Can anyone give me another idea? The only thing I can think to do now is hard wire ckt. 903 to 12v and/or re-wire ckt. 471 with a new wire.
OR is a 3 psi swing the best I can hope for with the stock WG at WOT in 3rd/4th gear?
smeagol
Have you tried working with purely mechanical boost control?
Base boost etc. If so, what results does that give you?
I'd also consider a high pressure actuator...
I am not a fan of Mitsubishi turbos for boost control.... drives me nuts. Get it down, and it will vary with the weather.
Fueling will play a part in boost control, have you tried adjusting fuel pressure to give best results?
Tooky
Serious about performance
Maxtor: Wow where did you get the elusive 12cm2 turbine as BG would put it? :D Do you have the stock converter? Does your boost control get better in cold weather? Are you sure your turbo to IC hose is not leaking or your IC to TB hose is tight?
Brian Green: When I disconnect the WG Solenoid on my stock turbo, the boost will be low in 1st and 2nd but in 3rd it will rise higher, is that normal or is there something wrong? Is mechanical boost control supposed to regulate to a certain PSI or just keep it generally lower? Is disconnecting the WG actuator rod off the pin, different than unplugging the solenoid? Thanks.
Maxtor
I did bypass computer control, boost is very solid between 10-11psi.
Funny you mention the weather, Brian. I DOES seem to effect this situation. Both days I thought I had fixed the problem, it was below 45deg outside. Today it is 75+ and boost is all over the place.
I have not tried varying FP - forgot about that. I have it set at around 45PSI (haven't checked it in a little while) which is the minimum I can run to keep my truck "happy".
KR is very low - peaks at 1-2 deg during shifts with alcohol spraying. Alcohol on/off doesn't seem to effect the boost control but KR goes up to 4-5 deg. at shifts and IAT's are higher without the alcohol.
I'll increase FP and try it again. I will also look into a high pressure actuator. Does PTE sell them?
Thank you, Brian - I really appreciate the suggestions.
smeagol
Mechanical boost control *should* give you solid boost levels across the gears, IF (big IF here) you had a wastegate setup that was halfway decent, as well as a properly sized turbo. A stock Syty has neither IMO.
A customized chip would help, what you'd probably need to do is do a bunch of runs on a scan tool, then customize the wastegate duty cycle versus MPH. Even then, the control varies with weather, and you'll be out some cash for the custom chip work unless you do it yourself.
A high pressure actuator may or may not help the situation.
My recommendations for solution vary depending on the person, the application, their budget & future plans.
Big money? Do an external with electronic boost control. Go look around, those are consistently the people who have least troublesome boost control. Want to keep all the hardware as you have it? Call up Dig, or start learning to chip (this can be almost as frustrating a situation as you are in now). Planning to go bigger in the future? Save for the PTE setup, or another decent turbo setup with an external. An expensive electronic controller isn't going to make things any better right now IMO.
Sorry for the lack of a clear answer, but there are too many variables here, and much of it depends on calibration matching the vehicle & weather.
Maxtor
Tookycat - I got the 12cm2 housing from Chan and have a 9/11 converter.
I have started looking at the code for customizing my own chips. I have an EPROM programmer and everything else I need to get started except time. Hopefully over the next month I will be able to spend more time working with it. Damn job keeps getting in the way.
I'll take a look at WGDC vs. RPM. I currently have about 35 datamaster runs stored with this setup so at least I have a good baseline! Thanks agqain.
Maxtor
It seems as though a custom chip is my best solution with this setup. Thanks for the suggestions.
I am in the process of getting the parts together for the DIY WB02 as well, SeattleSy. The PC boards are back ordered right now. I just hope Brian or someone else on the BB can help me tie it into the stock ECM so I can datalog once it is built.
I realize chipping can/will be just as frustrating, but after all - what isn't on these trucks? At least it won't cost me as much skin off my hands as the 9/11 install did!
BPATT
I was having the same issue about a year ago. I followed almost the same steps you did to trouble shoot the problem. I was getting ready to go tthe the electronic set up and external wg. But I wanted to hold onto some money for a little longer so. I decided to try the ATR manual I didn't like the idea at all but I had to try $40 compared to the hundreds that I was going to spend. Do you know my boost has been solid since no spikes anything. I don't care for the way it is now but it worked.. This might help you out until you figure out what you really want to use to control you boost.
