Re: boost control on stock turbo
There is so much bad/wrong info in this thread... gotta be careful what info you pay attention to.
I personally wouldn't attempt to add boost to a 100% stock truck without having the right fuel system parts.
This would include a fuel pump (the walbro is fine) and an adjustable regulator. I would also not do it without some mechanism for watching the knock sensor (knock retard). A few seconds of knock at high boost, and your piston ring lands and/or bearings are toast.
Trying to add more boost (ie, more than 14 psi) on cheap street gas is foolish, unless you've done modifications to the intercooler, fuel, and ignition to make this reliable. Even then, you won't get much more than 16, given the state of most pump gas. There's a reason there's so many blown motors.
All aftermarket chips made before '98 or so (which includes *all* ATR, KB, Conley, Hypertech,JET, Dynotech,Ztech,Superchips, and all the factory releases) are made to run with a 2 Bar sensor. Running a 3 bar sensor with any of these will make them run like crap, if not cause outright damage.
The stock chips, and many aftermarket ones derived from it, have a function that will cut fuel if boost exceeds ~15 psi (varies with altitude) for more than 2 seconds continuously. Adding an external boost controller will give you more boost, which will just run into the cutoff. Some early pitbulls retained this cutoff, others didn't.
A 2Bar based system will make as much boost as the turbo is capable, generally 25 psi+ on a working system. Depending on how the fueling was set up in the chip, it could provide enough fuel to support correct AFRs at 22 psi. What it can't do, is tell the difference between 15 psi and 22+. If the chip was set up to run 18 psi, (as many Pitbulls were) it may have the correct AFRs at that boost level. But, it'll be lean at 22 psi, and rich at 15 psi, no matter what you do with an Adjustable Fuel Pressure regulator.
This is why the 3Bar code was developed, so that the system could maintain correct fueling at 15 psi and above.
Just because you have a 3 Bar chip + sensor, does not mean that it will work properly in your truck. It will only work in the truck that it was specifically developed in, or one that has the exact same set of modifications and engine wear that the development truck had. Since the variety of modifications and combinations is virtually unlimited, the odds that the chip that you're buying will match your particular truck are pretty slim. This is why people are adopting the tune-it-yourself mentality, and are having success with it.
The above applies to the ATR chip as well. Some trucks like it, others don't. Unless you're monitoring it with a scan tool, you have virtually no way of knowing, unless you're really good at reading spark plugs.
My advice to the original poster- don't mess with it. Make sure your fuel system is up to snuff, make sure your intercooler is working properly and is clean, and make sure your ignition system is in good shape. Then, get some scan tool software and a laptop (or find a local that has one), and find out what's really going on.
Try to do too much, too fast, and you'll have an engine rebuild to do.
