Re: BS3 users, engine harness options?
autoaddictions said:
If you chose to use the standard harness that comes with the BS3 you will have to splice into all the sensors.
So the standard harness you must (splice/solder) all your old sensor connectors, map,tps,iat,ect,est,coil,igniton module, except for the injector harness and 02 to the new harness?
The BS3 will not control a stock 700r4 transmission either you will need to get a trans controler from TCI or other to control the lock up on your stock converter. If you go all out and swap out your stock trans for a upgraded 4L80e you can contol that with the BS3 system. Thats going to hurt the wallet a bit more.
I did not know this, although it will control the newer 4l60E. The plans have already been changed for the 4l80E w/T-brake. Yes, wallet breaking. Does the standard harness come with a trans harness or must you reuse your old one?
I plan on removing all of the uneeded stock wiring rats nest to make for a very clean simple new harness. Im ase certified in electrical and am looking forward to the removal of most of the stock harness, a/c connections/relay, Ic pump connections/relay,egr,stock 02,abs,boost solinoid/relayand fuse at alternator,fuel pump relay. Ive already started and it appears the stock harness will not be able to be saved. due to the bulkhead connector at the back of the fuse block. Still needed for guage ect,power from alt,starter wire,trans harness,grounds(2),wiper motor, and thats about it.
