InvisiBill
I own a Syclone and an S-10 4x4. I've read two years worth of "Can I duct tape a Syclone turbo to my S-10 and make it run 11's?" questions. I know all that stuff...
There seem to be a lot of "barely adequate" parts that GM used on SyTy's, which get upgraded. I got thinking about starting from scratch with the upgrade stuff instead of stock. You'd still have to get SyTy-spec stuff, I know. But rather than trying to get a donor truck and do a transplant, just buy upgraded stuff to begin with. Get a McCoy motor, a PTE turbo and downpipe, ATR headers, an air-air IC, and a Hartman tranny (those are just examples, not specific plans or recommendations).
That seems to cover most of the SyTy-specific stuff right there, without actually having to get any actual SyTy parts. If you wanted to use the stock SyTy setup, I suppose you'd need the upper and lower intake still (see http://www.arautosports.com/TTcomplete.jpg for another option =) ). You'd need the ECM, which was used in a few other vehicles, right? Wiring harness? The transfer case was used in other vehicles as well. I know there are some different shaft options or something, but it seems like it'd be even easier to match things up if you were building the whole drivetrain from scratch instead of trying to transplant parts into an existing system. Would a regular 4x4 transfer case be able to handle that power?
Is there anything major I'm missing? I live in Hickville, and every time I pass a dirt road I think about how cool it'd be to have an old PoS-10 with 300 turbocharged AWD hp to tear around in. I realize that it wouldn't be cheap and I don't personally have the knowledge to do it, but it seemed like another logical path you could take...
