bypass wastgate?
Quickstop [UK]
Combating adversyty.
I haven't been getting more than 10psi on my truck for a while - I think the solenoid in the Greddy might have gone.
Is there a way to test it?
Otherwise how can I set the wastegate to remain closed all the time? Can I just disconnect the hose from the solenoid then run it to the backside of the wastegate so the boost keeps the pressure in there?
Obviously I'd not run it like this but just want to check and make sure I can get the 15 psi that I ran before.
MOD - can someone add the "e" to wastegate in the title? I hate bad spelling :D
Thanks!
bezerk
Re: bypass wastgate?
run boost line from upper port of ext. wastegate to turbo. and leave the bottem one off. Make a Clip when you blow that shit up :D
Big Mike
Lets see If we only knew an electrical engineer maybe he could figure out how to test it. Or you could disconnect the two wires from it and put one side to positive dc and the other to negative dc and listen for movement unless you like to hold things then feel for movement.
Mark maybe your Typhoon does not like American air, That is why you can only build 10psi.
Should I have my trailer on stand by for when you blow your truck up?
Quickstop [UK]
Funny guy :)
:rainbow:
:lol:
SY-1193
My turn...
I would be more interested in making my truck stop than making it faster right now. MR. QUICKSTOP isn't so quick to stop right now. Leave your truck and your AMEX with me while you go away....we'll have a team working on your truck to make it go 7.xx There is no limit on that card right?
0966Sy
Code what?
Thanks!
What turbo? wastegate? Boost controller?
bezerk
My turn...
funny that he get's these reactions from everyone he meets. Fix something first before you ask Q's about other things..he's like a chicken with his head cut off...
Hope your truck made the same progres over there, than it did here, if so..it should be finished by now.
If you ship your truck back, you need to bring me something in the back of your Ty.
Quickstop [UK]
GT35R, external Tial from RPM, Greddy Profec Spec BII
My turn...
Jeez I'm catching some abuse here! :D
Very funny Keith! I'll leave it with you this weekend and you can put my money where your mouth is...wait.... :lol:
Rene, what do you need? plenty of space! :D
