cam selection
skraypngm
Ok, heres the deal i know the stock heads suck but i have a pair that have been ported and polished pretty well with 2.02/1.60 valves engine bored .30 over and basically i'm trying to figure out what would be the best cam for these heads, any help would be appreciated Thanks..
turbodig
Re: cam selection
Also, what turbo do you have, and which torque converter.... also, where are your trans shift points set?
skraypngm
Re: cam selection
Thanks for the responses guys as for the chip it looks like it has a multiple tune chip from rpm so i would probally be sending it back to him with all the new specs as for smog i could care less, torque converter stall 2800 as for shift points i dont know and turbo i'm still working on that one i have a rpm setup downpipe external gate and some sort of turbonetics turbo i'm not to sure what size it is, how do you go about measuring these things exhaust turbine wheel?
