Tips and tricks I use
Tip #1: If the ECM is in limp home mode, NOTHING will connect. This can be from a bad upload to an emulator (ostrich) or chip installed wrong, backwards, and bent pins in the ecm. (done this one myself just recently).
Setting up COM port: As just about all new laptops now only use USB, many cables are either USB or must use a USB to 9 pin adaptor.
- Leave all cable unhooked
- Right click on MY COMPUTER
- Click on Properties, Hardware, Device Manager
- Notice if you have a section named (Ports COM & LPT) if you do expand that.
- Take a mental note of any active ports, now plug in your ALDL cable to the laptop.
- Remember what com port appeared, this is the com port of the ALDL cable.
- Now go into tunerpro (datamaster, etc) and select that com port.
- In tunerpro it is under Preferences, ALDL tab.
- Is your laptop even turned on?
- Are you using a stock bin, or a code59 bin and tunerpro? If YES, you must open the ALDL connection window. During the time the laptop is trying to connect send the silence ECM Command rapidly until it connects. (don't you wish you used code59 now?)
- Have you put your crack pipe or beer down?
Ok maybe the last one doesn't apply, but this should fix 95% of anybodies connection issues.
NOTE: Some laptops, programs force you to use com port 1-4. Back in device manager, if you right click on the port related to your ALDL, properties, Port Settings, Advanced you can force it to a com port 1-4 (95% of the time). Sometimes this will help.
Now that we have the port setting right, try to connect (at top in tunerpro is double blue arrows for a fast key).
If that didn't work, other things to check.
- Do you have the right ADS file selected if using Tunerpro? (www.code59.org if not)
- Is the chip in correctly both the adaptor if your using one, and the ecm?
- Are the pins where the chip plugs into the ecm bent?
- If the truck is running is the check engine light on? (could be in limp home mode, which WILL not connect even if you stand on your hand, rub your tummy and pat your head).
