Check Engine Light - Code 32
colinm5
Well, during my drive to work this morning, my check engine came on about 3-4 minutes into the drive. When i started to go home it was off, then about 4-5 minutes into the drive it comes back on. I pulled the code and got code 32. Sportmachines says i need to replace the EGR valve, but i wanted to see what you guys thought first.
"Vacuum switch shortened to ground on start-up, switch not closed after the ECM has commanded the EGR for a specified period of time or the EGR solenoid circuit is open for a specified period of time. Replace the EGR valve."
This would explain why it would it came later on in my commute right?
Thanks in advance for the help/advice
VermontTy
Support Our Troops
Re: Check Engine Light - Code 32
This is pretty common actually. The EGR code you pulled is because the EGR valve is not working. Whether its the solenoid, the vacuum line, or the valve is yet to be known, but it happens when the EGR valve doesn't function when the ECM tells it to. The check engine light comes on while cruising 55ish under light throttle, and the truck feels sluggish when the light is on, correct?
The way to fix it is
A) to replace the EGR valve and vacuum line (most likely the solenoid is fine) and at the same time, run a can of GM's Top End Cleaner through the engine; it takes care of carbon buildup in the plenum, etc. Carbon buildup can gum up the EGR and cause it to not work.
B) pull the entire EGR system off the truck and send your chip to someone who can reburn it, without the EGR code. If you pull it and add a block-off-plate, you'll still get the same code. Some of our tuners can go into the code of your chip and delete out the portion where the ECM looks at and controls the EGR system; very pimp, and probably $30 to have it done.
My :2cents: is to ditch the EGR system and have someone reburn your chip. If you decide to go that route, PM me and I can give you some names to contact....
-adam
colinm5
The light seems to come on at the same strip of freeway on the way home from work, but not in the morning going to work or when i cruise around at night,so im guessing outside air temps are contributing to this.
Removing the EGR valve would prevent it form passing CA emissions correct? So B would be out of the question.
How much would a new EGR valve+hose run for? But before that I'll definately grab a can of top end cleaner. Where can i find that at? Peb boys/Kragen?
Thanx for the help, the light has been bugging me whenever it comes on.
VermontTy
Support Our Troops
The top end cleaner, get right from GM for about $6. I think its actually called "Top End Cleaner". As for passing CA emissions, I dunno, the EGR only kicks on during highway cruising (ususally), so if you were hooked up to a sniffer in a garage, I don't think the EGR would be operational anyway. An EGR valve and gasket will kill $60; the hose is just 4mm or 6mm vacuum line. This is how the vacuum lines are laid out in the engine bay if you need that also.
colinm5
thanx, i was thinking about replacing my vaccum lines just for the sake of knowing that they are new/good condition. Also my a/c only comes out of the top 2 window vents, so tracing down the leak is also planned. what size/length do i need?
I would check the vacuum lines first. On any SyTy (they on exceptions would be ultra low mileage) they really should all be replaced especially if original.
VermontTy
Support Our Troops
Grab 10' of 4mm and 10' of 6mm, I think it ran me a whopping $11.
colinm5
Any suggestions on some good quality hoses? Or should i just run to napa and pick up some. Id rather have nice durable lines even if they run a little more $$.
