colinm5
Well, during my drive to work this morning, my check engine came on about 3-4 minutes into the drive. When i started to go home it was off, then about 4-5 minutes into the drive it comes back on. I pulled the code and got code 32. Sportmachines says i need to replace the EGR valve, but i wanted to see what you guys thought first.
"Vacuum switch shortened to ground on start-up, switch not closed after the ECM has commanded the EGR for a specified period of time or the EGR solenoid circuit is open for a specified period of time. Replace the EGR valve."
This would explain why it would it came later on in my commute right?
Thanks in advance for the help/advice
