Hey Guys....
I got to thinking about this while in the shower, and decided that it was worth a second look and an actual engineering evalutation.
Here is what I dug up. Specific Heat of Gasoline (Cp) is .53 BTU / lb F, Specific Heat of Air (at standard temp and pressure) is .24 BTU / lb F, Specific Heat of Water is 1 BTU / lb F (it is the reference point for the scale). What this means is it takes twice the energy to raise water 1 deg F as it does Gasoline (and 4 times the energy of air).
Here are my assumptions.
Say its hot, and therefore the gasoline in the tank is hot (say 100 F). We pump it forward and it gets warmer (call it 135 F for easy math). If we inject it in the engine, its is in its liquid state, and therefore gets to the boiling point and then vaporizes. If we cool it, that part won't change any.
Say we install a cooler, and drop our 135 F gasoline down to 35 F (nice and cold). What happens now is that the gasoline has to get from 35 F to 135 F before it is just as before. So we have created a difference. What is that difference? Depends upon amount of gas we pump in.
Lets assume we're using 6 50 lb / hr injectors (at 100% duty cycle), therefore they flow 300 lbs of fuel / hr. Obviously we won't run the engine at peak power for an hour, or should we be using 100% duty cycle, but play along for fun.
Here's the formula: Q (amount of heat in BTU's) = Cp x Mass (in lbs) x Temp change (in F). So, if we get 300 lbs of fuel to rise from 35 F to 135 F, we ge 15900 BTU / HR (for the record, a "ton" of air conditioning is 13500). Thats a significant effect.
Seeing what the impact will be on the air temperature, we use the same formula to solve for Temp Change. Need to know the amount of air (lets use 11:1 AFR) which yields 3300 lbs of air / hr. At that point we get a 20 F decrease in air temp. This assumes that all the heat that is raising the temp of the fuel is coming from the intake air charge, which probably isn't 100 % accurate. This also assumes that the specific heat of air at 15 psi of boost or so and 150 F is reasonably close to the above listed specific heat (which it might not be).
Conclusion (besides wow, thats alot of typing). In NA race vehicles, it probably is worthwhile. In turbo'd vehicles, it may depend upon a bunch of other things as to whether it is worthwhile or not. Like do you have space, how big / good / efficient / etc is you intercooler, how much will your installation cost, etc. I probably should have run a calculation as to what lowering the intake air temp by 20 F would do (as far as horsepower / torque) but I didn't.
If anybody has read this far, please make sure that I didn't make a stupid assumption / math type error, or some other kind of dumb mistake. The stupid mistakes are the one's that usually get me.
'Dreamin'
