Chip in Chicaoland
8sec240
I have a customers truck here with chip issues. Current chip is a disaster. Open loop with unknown operating parameters. The truck has a 3 bar map sensor and Accel 30# injectors in it. High 900mv at idle and low 200mv at cruise and WOT.
Will be happy to get a 2 bar map and a stock chip if someone has one available.
SBNova
Re: Chip in Chicaoland
Stock injectors are 33lb. I don't know why anyone would go down in size. How do you know its in open loop? If you can log post your log file here (TunerProRT or Datamaster) There are stock SyTy chip binaries available for downloading at Moates' site, or I could email you the latest stock SyTy binary file and you can burn it to a chip. These would be 2-bar, 33lb injector chips.
8sec240
I didnt install the injectors, I am working around them though. IIRC, stock injectors were around 28 lb so these should be in the ballpark.
My scan tool shows the truck never goes closed loop. Block learn never moves from 128 despite idling at over 900mv. No CELs.
I do not have a UV eraser nor do I have a chip burner or hex editor so I just cant go that route.
Thanks for the offer. If anybody has the capability to burn a chip quick I have spare memcals I could send you.
Silly
Banned
Hello Ivan, looks like you posted about a week too late. I just got rid of a stock chip for nothing, threw it in on an ECM deal.
8sec240
I talked to BG and he said all his chip stuff is in storage. I emailed sytychips.com (todd I believe) and have gotten no response.
I would settle for an ATR Pitbull chip, stock.. just about anything for stock size injectors.
I guess its time to call the local GM dealer... :(
8sec240
I have been thinking about this. My customer bought the truck with a blown motor and put a new motor in it and has had these running issues from fire up. The motor has about 25 miles on it now.
Anyway, I am thinking its possible this truck has a 3 bar map sensor and a 2 bar chip in it. This would explain the rich at idle and lean under WOT and boost issue....
Hmmmm... anybody got a stock map sensor I can borrow for like 5 min???
epix
Typhoon
8sec, if you can't find one locally I'll ship you mine to borrow, im in SW MI so wouldnt take long to ship it there
8sec240
I had the local GM dealer overnight a stock memcal and 2 bar map sensor.
I installed the map sensor and turned the ignition on. The factory boost gauge sat in the correct position (not at the first devision in vac like the 3 bar) I started the motor up with my scan tool in place and the O2 mv were in the low 800s. As the truck warmed up the O2 did not drop and the truck never went into closed loop.
I shut the motor off and installed the new memcal. With the new chip, the truck fired right up and went into closed loop before I could even grab the scan tool to look. O2s transitioned and the block learn started to cycle.
I really dont know what the deal was with the chip that was installed in the truck but it was bunk for sure.
Thanks for the leads.
8sec240
I have no clue what chip was installed. The sticker over the eprom was removed and the chip had an ID of 1003 on the scan tool. What ever it was, it was junk.
The stock map sensor and chip FTW!!!!
I had to turn the fuel pressure down to get long term fuel correction to 128 which leads me to believe that the 30lb Accel injectors are larger than stock. I dont know what final fuel pressure was but I am 2 turns out on the FPR which WAS based at 45 psi with vacuum off.
There is a night and day difference in the way it runs now.
Maybe somebody knows the truck. Its a very clean black 92 with cladding painted to match the upper. It also has custom TYPHOON logos air brushed in blue on the doors and tailgate. Its running a PTE bolt on turbo. No other major mods. My customer bought the truck used with a motor that smoked out the valve covers really bad.
