CHIP Questions - HELP....
ProStreetMike
Cruising through AZ.....
First, let me start by saying that my truck - 1992 Typhoon #2067, is clean, and almost all original - it has the following changes -
Walbro pump - Kenny Belle Intake and cone filter - Intercooler pump is hard wired to ignition - AND - Stock turbo, stock original injectors, and heads. Truck has 118k on it.
Now - I see the JET and Hypertech Chips in SUMMIT for under $175.... are they any good??
I have purchased a 3-bar Map, and an older Ultimate chip for a stock engine... it looks and appears to be fine - have not installed it yet... (kind of scared to hurt my truck...)
My intentions with my truck are to run RELIABLY in the 13.00 range on 91 pump gas.... can it be done, and do you guys have any recommendations?? Is there anyone here in AZ that would be willing to take me under their wing and help me through these issues and fears??
I just dont want to hurt what is a GREAT, clean, 14.05 truck.... HELP!!
Any help, advice, and available parts - woulds be appreciated - I have paypal, and just want to do this right....
FEEL FREE to call me or email me direct -
Mike
480-797-9958
prostreetmike@aol.com
Jimmy
Banned
Re: CHIP Questions - HELP....
The Jet and Hypertech won't hurt anything,but they aren't worth anything.
The Ultimate will be your best bet since it can advance timing and boost and fueling.
No comparison there.
As far as running 13 flat stock,that's cake.
Juat make sure you are using a scan tool to log your runs,don't knock it,don't go over 17 psi on 93 octane,and don't go lean.
If the truck is running 100% it should go 13 flat on 17 psi with 14 degrees advance,all day long.
You need to get a AFPR, a fuel pressure gauge,and a boost gauge,and Datamaster if you don't have it.
I would also suggest a Gilbert propshat,a deep tranny pan,and an external tranny cooler.
Also brake torque the motor with the hood up to be sure the DS motor mount is not broken.
Do you know how to boost launch?
ProStreetMike
Yep - been racing for ages - so I do have a boost guage - what Fuel pressure regulator do you recommend and where can I get it?? Anyone have a good used one they can part with?? Is the install a piece of cake??
So do the Jet and Hyper chips do anything at all?? (just asking...)
NecroWolf
lost marbles member
any of our vendors will have the adjustable fp regulator, HERE is a link to one at syty performance. i ran a 14.2 when my truck was all sorts of messed up so a 13.00 shouldn't be hard. if you have a stock front driveshaft that has to go, i broke two with a stock motor.
ProStreetMike
Thanks Jimmy and others - So where to get a solid Front Drive shaft?? Anyone got one they want to part with???
Anyone in AZ who can meet and maybe help out??? Any clubs here in AZ???
Jimmy
Banned
No.No.No.
You are pretty much on your own man,except for the help here.
They didn't make 10 trucks per state,and maybe 1/2 of them are left?,and nobody gives a poo aboot a Blazer with a body kit? :haha:
Contact Gilbert Driveline Service & Supply
Phone: (603) 623-3061
His shit is 10 foot tall and bulletproof. :tup:
turbodig
All they really did was mess with timing.
For your goals, find yourself a old Pitbull chip, and throw some 100 octane no-lead in it.
Racing it reliably will involve a big trans cooler, an auxillary cooler for the IC, and a scan tool to watch for knock.
If you're not monitoring it, it's a matter of *when*, not if, you're going to be redoing the motor. This goes for the Ultimate, or any chip for that matter.
msheller
So they do or don't allow more boost? any one try 18psi on jet chips chip?
Matt
jpalmer
He got rid of it months ago Ian. I told him they sucked before then. I need to call Mike again to see how he is, and how his Ty is doing. clean truck, fo sho! :tup:
turbodig
Matt
It wasn't so much of an "allow" thing. Most of the aftermarket 2Bar chips upped the overboost cutout to the max value. They also usually set up a fixed duty cycle on the WG solenoid, so you'd see higher boost levels depending on where your WG rod was adjusted.
As far as fueling goes, it was sort of a crap shoot as to whether or not it worked with your truck.
The Hypertech pulled timing from the high end of the F1, as I recall. The idea being that you'd use a bleed valve of some sort to up the boost.
The base Jet was similar, although they did a bit more with timing. The Lee Howie Jet was a custom thing that added lots more timing... I ran a 12.6 in an otherwise stock truck with that, on the OEM tires, on 110 octane.
The problem with any of these, is that they were an attempt at one-size-fits-all. Well, one size doesn't fit all in the real world. They might work ok on one truck, not at all on the next, and will blow the motor on another one.
If you run any of these, monitor them really closely. (ie, DataMaster)
Tunerpro will likely have issues trying to connect to these, since none of them have the ALDL patch.
thunderace31
There is a ton of great info here but what about the people like me that are totally dumb (maybe not dumb but have kids and lack the time to set with this stuff for weeks at a time) and have a hard time following along with the code 59 chips and all the other jargon going on here? Whats the best chip to get and who or where can it be purchased?? I have always use Eric at turbo Tweek for my Chips for the GN and have nothing but good things to say about them. There simple to use and you can change things with them by using simple things in the car. (If you dont know them goto www.TurboTweek.com and do a little reading very cool super easy to use stuff)
Anyway All I want is something super easy to use and not confuse the living crap out of my Simple little pea brain lol. I know all about using the date logger soft wear and really wish there was a simple scanmaster made for these trucks as the are nice to have mounted on the dash so you can see your knock right there when your under boost and know if you need to let off or not. (I have not found any thing like it for the Ty)
And as a side note I have a GN that runs in the low 10's on alky Stock computer and a Dual BB 70GTQ turbo and an Eric Marshall chip (AKA turbo Tweek) :)
Thanks for the help and info in advance :tup:
turbodig
This is the essence of the problem - people believe that such a thing exists. Or, they want to believe one exists.
There aren't any "plug-it-in-and-it-will-go" chips for Syclones/Typhoons. They aren't like Buicks.
You can still buy them, but it's even-money odds that they won't work, or you'll end up with a dead motor eventually.
It's an unpopular truth, but there never has been one. If it was sold in an "off the shelf" manner, it didn't work repeatably- there were some that were better than others, but at the end of the day it was really a crap shoot on whether or not it would work.
That being said, you can have a custom one done to your application, but it'll require that you have something to record data, and wide-band o2 to see what fuel is doing. Nolan does these, so does Hood.
If you don't want to work, or don't want to think, you won't have good results with Sys/Tys period. You're better off leaving it stock at that point.
You can choose to believe this, or not.
(My 15+ years working with the ECM in these things might make me completely off-base, but who knows)
But look around... how many blown-up motors are there? How many screwed-up heavy-breathing trucks?
thunderace31
What makes these truck so much harder to work on than a Turbo Buick?? I have no issues with Reading 02's or data logging with directscan I do it all the time on the GN thats easy for me. But reading a Goofy graph or a Fuel map seems to send me off in loopy land. MOst of the Systems I have work with are very hard to tune. I had the Full Throttle Maftpro deal for a while and I never got the car to run right I just didnt have the time to set and mess with all the things that can be changed and when I did mess with them a lot of the time things went for the worse and didnt improve so I was back to square one again and again and again and I finely had someone else tune it and they even had issue with that system. From what Im seeing its the same Tuner pro deal yall are using for the typhoon. It was done by Bob Baily and Mike Litch or they had a hand in it. I know a thing or to about buicks but these are a new animal I really want to make work right. But as with anyone with small kids time and peace and quite are hard to come by. (Im sure others will agree here) I do not understand why these are so much diff. and No one is really explaining the reasons for this.
Back to my question if these are obd1 what makes them so diff. the Turbo Buick is simple and Now Im wondering how to make that computer system work in Ty :) I bet it will being I have a 4.2L Buick in in the GN :)
