clipping?
I ran across some dsm guys talking about clipping the turbine. They said it's comparable to swapping in a bigger turbine wheel. What exactly is clipping? I don't think I've ever heard it mentioned here. Thanks :drinking:
jwaller
Evil Genius/SyTy Guru
clipping as I've seen can be 2 things. trim the outer edegs of the turbine wheel thereby giving less surface area and making less restriction.
second reducing the angle of the turbine blades.
Ian Turgeon
Cascading Inspiration
if Im correct both increase lag/spoolup of the turbo. I think they are methods used to decrease restriction on an otherwise undersized exhaust housing/turbine.
