CLOSED LOOP...
qbnkiller
Conflaguration Specialist
can anyone here explain to me how to get the truck to run in anything other than CLOSED LOOP? I was working under the hood changing the PCV valves, and when I put everything back together, the truck now never gets out of CLOSED LOOP mode. I have an Ultimate V9 chi, 3BAR MAP, and new O2 sensor.
Rds.
QBNKILLER
G
Guest
Guest
The only thing i run in is open loop. Hmm.... disconnect your o2 sensor.?? :)
qbnkiller
...well, still haven't found out why the hell this truck is acting like a whore! Damn thing was running fine before I replaced the PCV valves, and now it is stuck in CLOSED LOOP!
Attached is a small DM run, showing something weird...maybe those of you who are experienced can shed some light...I thought it may be TPS unplugged, but seems to be fine...then I thought O2 may be disconnected....fine...???? :fist:
...crap! Can someone please host my DM run for a few days? PM me...
Thanks in Advanced!
qbnkiller
qbnkiller
...OK...have replaced (again) the O2 sensor and put the truck back to stock (2BAR and stock chip and 42#FP). Reset the PCM and tested again.
At the moment of connection, the truck will show OPEN LOOP for about 3-5 seconds, then revert to CLOSED LOOP. I notice that through the DM display, it says that the system voltage is 12.XXVDC. I hook up my meter, and it shows 14.XXVDC. I pulled up some of my old(last year) DM runs, along with a few of the sample runs that came with the program, and in all but 2 runs (Phils runs???) it shows the PCM in CLOSED LOOP all the time. In those 2 other runs, it stays in OPEN LOOP until the water temp reaches over 70.7 degrees F, then jumps into closed loop. Is this normal? Am I misunderstanding something?
Anyways, I started looking at my normal DM run when I first got the DM and truck, and started comparing them, and it seems that I am pretty close to where I was last year. Now....the tuning questions...
1. I am going to put back the 3BAR and Ultimate. I will adjust the FP to 50-ish# with the VAC disconnected. Re-check timing. Then, using the DM's STERM and Knock display, raise FP until I get a happy medium that the PCM likes (taking out less timing).
2. After I get the above accomplished, I will install the Alky unit, reduce FP a little, and start tuning again like above.
As usual, any insight from experienced tuners is greatly appreciated.
Rds.
Alex
PS: To make matters worse, I have been invited to bring the truck to a local Chevy Dealership for a private car show they are having. You know, I may have to put a little rubber down after the event, if necessary 8)
leroy
There's nothing wrong with closed loop. Closed loop means your O2 sensor is being used for feedback to adjust the fuel. Open loop can be commanded full time by changing a couple of things in the chip. Open loop may help the idle quality or aid in the tuning process.
HTH,
Jim
leroy
I think you are on the right track.
For WOT tuning, a wideband helps. Without wideband, you should probably be reading plugs. In fact, you should even read plugs with wideband to make sure things are okay. Try a google search for "reading spark plugs", or something similar to learn more.
Water/alcohol injection is insurance for your motor. That can backfire if you rely on it too much. For example, what happens when a nozzle gets plugged, pump fails, etc.?
Good luck.
Jim
