I meant removing the cluster is the only way to change the bulbs.SYO237 said:its the only way?
Its not very hard, just make sure you have a magnet end on whatever tool you use to be able to remove and put back the screws that hold the dash housing in place.
Remove the light switch panel and AC control panel and your golden. Be careful on the AC side as its easy to damage the controllers and you might get stuck with permanent hot or cold.
