Cluster Bulbs
JAY
I think it's the only way. Just remove the heater controls and headlight switch area, then bezel and bolts holding cluster on.
SYO237
SyTy Registry
its the only way?
Its not very hard, just make sure you have a magnet end on whatever tool you use to be able to remove and put back the screws that hold the dash housing in place.
Remove the light switch panel and AC control panel and your golden. Be careful on the AC side as its easy to damage the controllers and you might get stuck with permanent hot or cold.
JAY
SYO237 said:
its the only way?
I meant removing the cluster is the only way to change the bulbs.
goalie29
That's what I figured, but thought I'd ask. Any guesses on how many bulbs are back there? And the bulb number?
Thanks!
