My 92 Ty has been getting an intermittent Code 31 when under hard acceleration. My mechanical boost gauge (plumbed into a tee off of the brake booster intake fitting) shows ~17 psi when the fault occurs. It started getting worse (happening more often) a few weeks ago, which led me to install the mech gauge, and eventually replaced the wastegate solenoid. This got me back to the occasional fault level. I have replaced the MAP sensor, and run through all the Code 31 checks from the service manual (all passed), but the problem persists.
I have Datamaster, but have never used it (plan to try it out this weekend).
The truck is mostly stock, except for a 160° thermostat, underdrive pulleys, cold air box, and ATR Cat-back exhaust.
Does anyone have any suggestions of where to look next?
Thanks and regards,
Michael
Thanks and regards,
Michael
