Re: Code 35
:rant: So I have been figting with this code for awhile now and its got me completly irritated.... So a code 35 is idle speed error, I allready have replaced the IAC valve(2x), EGR valve, and checked for vacuum leaks (none holds at -18 to -20) Ive tried adding fuel and leaning it out(reset ecm after every fix).. Nothing has fixed it :banghead: the only time it comes on is when the truck is either in park and idles for a little while or when stoped at a light for a little while once the truck starts to move again the code goes away.. On occasion after a hard acceleration the truck gets a surging idle of about 500rpms but no code is thrown.. The only thing I havent tried is replacing the stock cat and replacing it with a 3" since the Dp and exhaust(excluding the cat) is 3"... I dont know what else to look for or fix.....
Syclone11, are you still driving this truck? did you get this prob fixed? Think I'm having a similar or same issue. I was just about to fire up my truck when I was getting DM ready and it started pinging like mad. ding ding ding! So something is already wrong and I haven't got it started yet?
Just trying to record a DM file and I'm seeing under the "engine dtc" window..."MALF 35: IAC Error", cell number 3,5.
Recently (last 2 or 3 drives) my speedo kept dropping to ZERO after driving for 5 or so minutes. Shows no speed. Shut it off, speedo comes back...for five or so minutes. Anyone? I'm just now getting some time to look, hopefully today.
Only changes since it seemed to drive normal was I put my ECM in the glovebox, done it before on other truck=no problem.
:idea: I'm going take a run :turbo:, get some coffee, switch out to a different chip, and see if my scan picks up anything. Any info you guys may have please get it on here and get this thread rolling again so I can fix my proplem I'd appretiate! Thx.
