ZavzTy547
Senior Member
I did a search and a few people have had this issue with the same chip in the past but no real fix so I'm looking for suggestions on what the problem could be.
So here's my story...
With the ultimate installed (with the eprom installed correctly), the truck will idle very smooth but only 75% of the time....
25% of the time it will throw a code 42 and have eratic idle, then the check engine light will flicker and the ignition seems to turn off and on and the ultimate setting will actually change by itself from T1-22 to T3-24....
It finally got worse yesterday when the check engine light stayed on (code 42 again) and now it barely idles, almost like my alternator went out and it's running off the battery but my charging systems NORMAL (14volts).
I suspect:
1 Bad Grounds
2 Bad ECM
3 Bad Eprom
4 Bad 3 Bar Map Sensor
5 Maybe- Bad Fuel Pump or fuel injector?
Any suggestions?
Thx
Zav
I suspect:
1 Bad Grounds
2 Bad ECM
3 Bad Eprom
Any suggestions?
Thx
Zav
