BoostedSUV
I am getting a code 42 on my truck, I don't have a scan tool so I am checking it the old fashioned way by jumping the connector and counting flashes. The truck has a miss at about 300 rpms but clears up before and after. Timing is set at zero with bypass disconected. Also the truck while drving at cruising speeds it will act like its going to shut off real quick and return right back to normal. Has new plugs, wires, cap, rotor, etc. I just installed a new engine, 3bar map, 50# injectors and upgraded my 10n1 chip to an ultimate. Any ideas what to check?? Or how to clear the code?? thanks
