code 42!
BoostedSUV
I am getting a code 42 on my truck, I don't have a scan tool so I am checking it the old fashioned way by jumping the connector and counting flashes. The truck has a miss at about 300 rpms but clears up before and after. Timing is set at zero with bypass disconected. Also the truck while drving at cruising speeds it will act like its going to shut off real quick and return right back to normal. Has new plugs, wires, cap, rotor, etc. I just installed a new engine, 3bar map, 50# injectors and upgraded my 10n1 chip to an ultimate. Any ideas what to check?? Or how to clear the code?? thanks
SYO237
SyTy Registry
Re: code 42!
CODE 42
ELECTRONIC SPARK TIMING (EST) CIRCUIT
4.3L TURBO (VIN Z) SYCLONE AND TYPHOON (PORT)
Circuit Description:
The ignition module sends a reference signal (CKT 430) to the ECM when the engine is cranking. While the engine speed is under 400 rpm, the ignition module will control ignition timing. When the engine speed exceeds 400 rpm, the ECM applies 5 volts to the bypass line (CKT 424) to switch the timing to ECM control (EST CKT 423).
When the system is running “ON” the ignition module, that is, no voltage on the bypass line, the ignition module grounds the EST signal. The ECM expects to see no voltage on the EST line during this condition. If it sees a voltage, it sets Code 42 and will not go into the EST mode. When the rpm for EST is reached (about 400 rpm), voltage will be applied to the bypass line, the EST should no longer be grounded in the ignition module, so the EST voltage should be varying. If the bypass line is open or grounded, the ignition module will not switch to EST mode, so the EST voltage will be low and Code 42 will be set. If the EST line is grounded, the ignition module will switch to EST but, because the line is grounded, there will be no EST signal. A Code 42 will be set.
BoostedSUV
Re: code 42!
how do i fix this? where do I look? I noticed when the air/fuel gauge is steady on the rich side the trucks runs perfect. the gauge starts to act irratic and "turns off" showing no indicator bar. that's when then truck loses power and breaks up. It only does this at cruising speeds, under acceleration its fine.
TYGUY
Re: code 42!
module is in the distrib. if i am not mistaken you have to take out the distrib. to replace the module.
BoostedSUV
Re: code 42!
starting doing it after I installed chip, injectors, map sensor, and new engine for the third time. .... it's an intermitten problem not all the time.
TYGUY
Re: code 42!
my experience has been that the modules can do funny things.. only act funny when hot, or only when cold. if thats the code you have, you have no reason not to change it.... have you ever changed the distrib?
BoostedSUV
Re: code 42!
i have never changed it, but it worked fine before i put the new motor in for the 3rd time along with a new chip, injectors and map. Air/Fuel gauge acts irratic as well when the truck stumbles and kicks on the light previously. Code 42 was in the history, not showing any light at this point but still not running right.
BoostedSUV
Re: code 42!
its seems to have a problem between ~1500-2500 range. would that still be ign. mod?? A/F gauge reads dead lean or no reading when the truck stumbles and throws on the light.
TYGUY
Re: code 42!
this is what you wrote, this sounds like a module
turbodog
Re: code 42!
Another thing to check (just happened to me). If ECU was recently R&R'd, there is a chance that the wiring harness is chafing against the upper ECU mounting bracket. After a heater core R&R, I started getting code 42 and also overboost. Had to get emissions checked this month, so needed a fast fix. On a hunch, I pulled the ECU. With ECU on passenger floor, no codes. Checked the wire insulation, sure enough it was nicked in several places. I carefully reinstalled, no codes for a week (and passed emissions :tup: ), but then started in with code 42 again. Pulled ECU.... no codes. I plan to grind that bracket to give additional clearance.
Of course, YMMV, etc.
