Code 59 or Turbotweak chip?
Vaders Sy
Planning on tinkering with a stock turbo truck and bolts-ons. I also plan on using alcohol/meth. What are the pro and cons to both. No real experience tuning myself. Which will make the most reliable power to run low 12's? Let's hear it!
proptop
Re: Code 59 or Turbotweak chip?
Vader,
PM your questions to Eric/Turbotweak on this site. He is a stand up guy and can help you with all of your needs. We run his chips in a Buick GN and Turbo TA. Also I am just about ready to give one of his 80lb chips/setup a good testing in my Syclone. If you want PM me your number and I can give you a call if you would like.
Thanks,
Bob
Vaders Sy
Vader,
Thanks,
Bob
I know Eric Marshall will probably push his own product and that is understandable. I have had a turbo tweak chip in the past, but possibly wanted to try code 59. I see some people running pretty good times using it and wanted a unbiased opinion preferably someone that has used both. I'm sure either one can get the job done. Just wanted some info. I have never used it code 59.
I might take you on your offer Proptop.
I think code59 is a great solution IF and only IF you want to get involved in the tuning process, learn it, do it, try things, etc.
If you don't want to invest some time in education of tuning, setup, etc. Eric's chip fills a nice solution.
Vaders Sy
I think code59 is a great solution IF and only IF you want to get involved in the tuning process, learn it, do it, try things, etc..
For me, I would like to learn. Leaning toward the code 59 route, but would need help setting it up and getting stuff together. In short, would need a knowledgeable mentor. Will the end result be the same or will one have an advantage over the other in regards to output and drivability etc
Static
I messed with code59, learned the tables, had a few folks in the know look at and help me with tunes and effectively got nowhere in a 2 year period. Switched to Turbo Tweak and got up and running very well in a matter of hours. Code59 is complex but has a bunch of fine tuning capabilities that TT does not have. TT has just a few parameters and is user friendly. For what you are going to do with it I would go with TT.
Vaders Sy
Just curious, did you start with some of the base tunes from the database or Josh Straub's files at powertuneplus.com? What you experienced would be the big downside especially if I do not have much experience.
I'll probably call Eric and talk to him first.
12secondSY
Syty Killer :(
I ruined a $10k engine tuning with code 59 and I'm pretty goddamn smart I think
Static
I started with some of the base tunes and tuned from there. I pulled a lot of the timing out of the tables to reduce knock since adding fuel would not help. Could never get boost under control, I ended up getting a Forge wastegate to eliminate that problem entirely. I think the biggest downside is lack of support, Tunerpro 5 files wont work with the current autotune which hasnt been updated in 2 years? Dont get me wrong tho, code59 is a powerful tool and theres many guys out there tuning with it. If you go that route I would find someone local to you that can really help you out.
randy merritt
If you can afford it, the Holley HP or similar self learning stand alone computers are the way to go, hands down. I went through the Ostrich with code 58 tunes, then Code 59. Lots of hassle and asking others for help. The HP accomplished in about 8 hours what Code 59 would take about a few months of constant tuning, dyno time, etc. The HP is the best investment I have ever made in my truck.
Gnocide
turbo game burt reynolds
turbo tweak
unless you like burning, burning again, re-burning again etc
turbo tweak will run the truck without adjusting but to get the most out of it like alchol you should get to know tuning.
randy merritt
Can you be more specific, what is exatly needed or what product you got?
Holley HP has several different options to choose from:
https://www.holley.com/products/fuel_systems/fuel_injection/hp_efi/ecu_and_harness_kits/
Easiest way is to either call Michael Hood at Hood Tuned Performance or Alex at Steve Morris Engines. Either one of these guys can sell you a HP or Dominator setup with the correct wiring harness for a Sy/Ty. Their prices are very good also.
Vaders Sy
If you can afford it, the Holley HP or similar self learning stand alone help..
Trying to keep the truck in Stock Turbo class rules, so no stand alones are allowed. Unless rules have changed. One of my trucks has FAST XFI on it since 2005-06. Been doing more reading, swaying back to the Turbo tweak again. Sent Eric an email, waiting for a response.
wildphil
I Love My Ty's
turbo tweak
You don't have to burn any chips with code$59.
I have used it for years in is not for someone that doesn't have the time to learn how to tune. Its not hard but there is a lot of information to learn and can be overwhelming. I'm a dumbass and I have blown zero engines with it. You can do more fine tuning with it.
Most SyTyers would probably be a lot better off getting the Turbo Tweak chip. It sounds very user friendly and I have seen a lot of post by members that were very satisfied with the results.
That being said I am going to change from code$59 to a Holley Dominator on my Black Ty. It is modded enough that I think to get the most out of it thats the way I need to go. My Royal Ty is close to stock and I will continue to use code$59 for tuning on it.
Why build a truck for a race that happens at best every two year between 3 trucks. You still own it and drive it the other 729 days between races, build it for YOUR enjoyment.
Aeroking
e.i.
i tuned my truck on Code59 ran it for 5 years, and i loved it. The support from Jeff, Schwab, Dig, Scott, and others was better than Holley or FAST could have given me.
I followed their advice, and the learning experience was really gratifying.
The opportunity came up for me to get a standalone, so i switched. If you have the time, its great to learn something new.
I have used it for years in is not for someone that doesn't have the time to learn how to tune. Its not hard but there is a lot of information to learn and can be overwhelming....Most SyTyers would probably be a lot better off getting the Turbo Tweak chip. It sounds very user friendly and I have seen a lot of post by members that were very satisfied with the results
I agree. For the most SyTy owners, the Turbotweak chip is probably better solution. I am using code $59; I like the challenge, full control and rewards of doing it myself, but its not for everyone. That being said my tune still isn't fully dialed in. Its pretty good and safe, but I know it could be better and I haven't committed the time to finish it. (I am not sure if it ever is 100% done)
If you really want to try code$59, you may want to start off with the TurboTweak chip, to drive and enjoy the truck and then try tune on the side with code$59. It seems like your truck is a cookie cutter build, so the turbo tweak should be able to handle it.
Sean Krupa
Moderator
I'm running Code59 as well. I believe I'm one of the fastest trucks running it which I'm super proud of. I started using Code59 back when I was stock turbo and stock heads/cam. Now I have Vortec heads, Custom Cam and a Big Turbo. I've had a great help from Rob and the Ty wouldn't be as far as it is without him.
I will say that one day I will convert it to Holley being that, it's true, it won't ever be done and technology has progressed greatly.
