Code 59 or Turbotweak chip?
Gnocide
turbo game burt reynolds
Re: Code 59 or Turbotweak chip?
You don't have to burn any chips with code$59.
not burn chips- flash the tune
every time you want to change a parameter you have to open it, change it & re flash(or burn ).
bigger turbo - re flash
bigger injectors- re flash
pull some fuel- re flash
adjust timing- re flash
octane- re flash
all you gotta do with turbo tweak is change the number in the parameter setting.
way more user friendly- easier if you've never tuned for sure.
not as detailed as code 59 - but definitely easier
randy merritt
octane- re flash
This is exactly why the self learning computers are better IMO. You simply dial in the target A/F ratio, and the tune will hit it, no matter what the mods. Meth, straight gas, or E85. I am not saying my setup is better than anyone else, but speaking from a lazy guy that just wants to drive the truck and go fast, the HP has been a very good investment.
Having said that, the Turbo Tweak chip is a very good option.
Code 59 works well, but only if you are willing to put the time and effort into dialing the tune in.
Vaders Sy
Its good to hear others chiming in on the subject. Making a tough decision. What A/F wideband are you guys using and do you like it? Any recommendations?
Why build a truck for a race that happens at best every two year between 3 trucks. You still own it and drive it the other 729 days between races, build it for YOUR enjoyment.
Tinkering with a stock turbo truck and pushing it is the fun part for me
atkonkler
Is this your bush?
Plx...totally worth it...imo...a must have if your gonna roll with more boost.
Vaders Sy
PLX from what I read last night seems like the best weapon of choice. Going to get the DM-6. I also ordered another Turbo Tweak chip from Eric last night.
The Dread Pirate Fisher
If you have a turbo tweak chip, how does the PLX fit into the equation? I have an AEM Wideband,
Does the PLX hook into stock computer and use the wideband to read and use AFR?
atkonkler
Is this your bush?
The Plx is hooked into the ecm....it's not a plug and play deal....you must pin some stuff as I remember.....:tup:
Here's my .02.
I've tuned a ton of OBDII trucks/cars using HPTuners,everything from boosted V6s to cammed NA LS1s. It was overwhelming to learn; far more difficult than the OBDI stuff. That said, i'll probably tune my Ty myself, but on other projects, you can't beat the self-tuning systems out there. Their biggest downside is cost.
My Ty currently has a "custom" chip in it from a vendor and it runs terrible. My brother just bought a Turbotweek chip and it ran amazing right out of the box. I always tell people a good "box" tune will get you 80% there, but that last 20% really requires a custom tune to dial in the specific truck. The box tunes available for these trucks are actually really good, you can't say the same for OBDII stuff, there are more butchers out there who do stupid things to make their tunes "safe"
SpoolingTurbo6
I think all are good solutions and cover a wide range of mods and budget levels.
Remember all these options are born from a necessity. some fill a niche others don't, some combine most everything you'll need.
want someone to tune your ride based on general mods list = buy a chip
wanna be a tuner= code $58 and ostrich
experienced tuner = code $59 and ostrich + WB02
master all the above = go Holley
not saying any "one" has something better than everyone else, but they all have a time and place.
whats you level of knowledge and budget?
cjg454ss
I bought a turbotweak chip last fall. Have to reflash a bunch of times and now I'd like to switch to e85. Eric is unresponsive. The pump gas/alky tunes was average at best. Go with a holly.
Eric Sy GN
You just emailed me yesterday if you could buy some 60's and an E85 chip. Just answered it.
I also answered your post here: http://www.syty.net/forums/showthread.php?t=102876
We did 3 reburns, the first two were because the chip was ordered for the wrong wideband.
If you're not happy, please send your chip back and I'll send your money back.
It's just a six
Super Member
I run Code 59.
It was a lot of learning, main problem I initially had was getting a laptop to work with the files needed to use code 59.
I use Tuner Pro5.
My Sy runs pretty good, the tune is not perfect still needs a lot of tweaking but is totally drivable & fun to drive.
I just passed a smog check & it is great to be able to burn a smog test chip, pop it in & pass.
That is with a 160 thermostat. Thanks to code 59.
Also getting help from Mike Hood, Rob, Skywayb, Jeff Scott all excellent help!
Mr Hood, I would like some more tutorial videos on more tuning, AWESOME!!!
I have not taken it to a track in a few years, but , my butt dyno says its an 11 second pump gas 91 octane Sy.
