Re: Code59 fail safe
Constanst/Scalars
Boost Wastegate Control
Boost Reduction Retard Enable Threshold (KGEKCENA) 4.04
Boost Reduction Retard Enable Threshold (KGEKCDIS) 4.04
Desired Boost Pressure Reduction Delta (KBSTDLT1) 5
Desired Boost Pressure Reduction Delta (KBTDLT2) 5
How will these settings work? Is the reduction delta a multiplier or is that was it pulls over 4.04 kr?
This gives me more confidence to tune myself now that I can put some safety features in place. Thanks again for everyones help.
The top 2 are a hysteresis pair... the top one is the level at which it will start pulling desired boost, and the bottom one will be the level that it drops below before it stops pulling desired boost. They generally will be set 1 psi or so apart, so that the system doesn't sit and switch back and forth over the KR point.
The labels on the bottom 2 aren't the best (they weren't so good in the gm documents, either) .
Working from memory, DLT1 is the step amount that will be subtracted from desired boost when the knock threshold is reached, and DLT2 is the step amount that will be added back in once it's gone.
I'm fairly sure that I did a write-up on these and the other settings on code59 someplace, I'll see if I can find the link.
It's important to note that these are deltas to desired boost, *not* WG DC. So, these settings tie in to the step settings you have for general boost control rate. This also means that they're pretty slow in relation to the reaction to knock events. The code really needs to change to make these deltas to WG DC, so that you can more immediately open the WG when knock starts. Part of the plan with alky pump control was to tie this in to pump control, so that when knock crept in, boost would be pulled and alky delivery increased slightly.
A lot of the early chips disabled this, since it would do its job and pull back desired and eventually real boost. This made people think that the "chip didn't work", when the reality was that they didn't have necessary fuel system improvements or gas quality to support the additional timing and boost being run.
It became just another limiter that chip makers "removed".
All of this is really a reactionary approach to knock. My old friend Bruce used to say that the best way to get rid of knock was to never allow the conditions for it to start. Once it starts, it takes much more boost reduction and timing reduction to correct it than it would have to have avoided it in the first place - ie, you might have to pull 4 degrees and 3 psi to make it go away, when taking 1 psi and 1 degree out of the table would have kept it from starting in the first place.
