I am trying to reset by doing the ECMB fuse pull since that has worked before. I am running the moates adaptor, bbzb memcal, and an ostrich. I was having problems with tuning this thing and removed the zif socket and swapped ecu's and that cured everything except this damn codes that wont go away
Try removing both ECM fuses, or just disconnecting the battery for a while. Code 12 is not really a code, it signals the beginning and end of codes. If you had no codes stored you would see "12" continuously.
I got them to finally clear by throwing the cutoff switch removing the ecmb fuse then restoring power to the truck and doing a power cycle with the key and the b fuse removed. Now I will see if they come back again in the next few days. After all the connection issues I was having with the ostrich and g1 and ecu I hope this is the end of it
