Complete Bowtie 4.3 on CL
WyoSyclone
Re: Complete Bowtie 4.3 on CL
I called the guy up and he seems like a good guy... this motor came from a shop that builds a lot of Nascar motors.... can't remember the name - Rimes, maybe??
In addition to what's listed in the ad....
Bowtie block
2-piece seal
odd-fire
high compression
572 n/a hp is what he claims
.590 lift
9200 redline
just parting it out would be worth it... he's run into some hard times with medicaid and is having to liquidate.
SY-1193
9200 Redline WOW! :shocked!:The oil must be whipped up like a frothy coffee.
WyoSyclone
He said it's set up with external oiling...wet sump now, but can be dry sump with a few parts... yes it would be frothy! I was helping a buddy last night check the lockup on the torque converter on his super-comp dragster....10k redline on that small block - yikes! - TQ was stalling at 7200.
Windedv6
Ty n 10s
I spoke to the owner today. The heads are going to be a difficult fit for us as they have been angle milled to a 12* valve setup. This not only takes a ton off of the deck but will play havoic with making headers. RPM's brodix headers will probably not fit and a custom intake will have to be fabbed. I don't know how much of the chamber is lost, but I would expect with a full dish piston the CR may still be well into the 9s.
Also the oil boss (where the filter or adapter goes) has been modified. I was drilled out and fitted with a AN fitting. Pressured oil only out, then to a filter and then feed externally into the front of the engine like a dry sump feed. This can not be reversed. It does work fine though, people just need to be aware that thats how it will have to be plumbed and used. The block is setup for a two seal crank, so a two piece billet crank will have to be used. In some bowtie blocks you can use a one piece adapter for a one piece crank. Until I see pictures of the rear side of the block I don't know if this casting can use a one piece adapter or not.
He didn't know if the cam setup was a standard juornal or if it was a needle roller journal cam setup, which would not take an even fire cam blank. Although you can have LSM make a billet cam for it (around $900), this type of cam setup gets it's oiling from splash only and would not last in a street driven setup.
I will post any additional information when I get it.
John
