starting a LS9 syclone swap with 6 speed auto
up for sale
engine
less than 1000 miles since built. complete 4.3 drop out including exhaust manifolds, oil pan, and throttle body. engine is a fresh 4.3 bored 30 over with forged pistons and eagle forged rods, stock crank. block has been line honed, balanced, and torque plate honed. rings are total seal gapless too with napier second ring. stock turbo
Stock heads ported with 5 angle valve job, decked and checked for cracks.
Ignition
ECU is a classic fast, msd distributor with msd cap and rotor. new gm ignition module, msd 50ohm/ft wires. iridium autolight plugs. Mallory 6a ignition box
fuel system-
Stock rails with Turbo Tweak regulator, 60lb injectors, Walbro 340 pump
Transmission,
built 700r4 with less than 2000 miles, stock torque converter
Stock wirining harness and ECU will be included. Classic fast with E85 and 93 octane tunes
I was thinking 6,500 for everything due to $9500.00 in receipts. all work is less than 12 months old except transmission which is 18 months old
up for sale
engine
Ignition
fuel system-
Transmission,
