complete drop out syclone motor
cjg454ss
starting a LS9 syclone swap with 6 speed auto
up for sale
engine
less than 1000 miles since built. complete 4.3 drop out including exhaust manifolds, oil pan, and throttle body. engine is a fresh 4.3 bored 30 over with forged pistons and eagle forged rods, stock crank. block has been line honed, balanced, and torque plate honed. rings are total seal gapless too with napier second ring. stock turbo
Stock heads ported with 5 angle valve job, decked and checked for cracks.
Ignition
ECU is a classic fast, msd distributor with msd cap and rotor. new gm ignition module, msd 50ohm/ft wires. iridium autolight plugs. Mallory 6a ignition box
fuel system-
Stock rails with Turbo Tweak regulator, 60lb injectors, Walbro 340 pump
Transmission,
built 700r4 with less than 2000 miles, stock torque converter
Stock wirining harness and ECU will be included. Classic fast with E85 and 93 octane tunes
I was thinking 6,500 for everything due to $9500.00 in receipts. all work is less than 12 months old except transmission which is 18 months old
Baythan
SY2TY2SY2TY
Re: complete drop out syclone motor
Just curious: Location?
Do you have dyno or video of engine running before pulling?
cjg454ss
Sure do, motor is still in the truck current. forgot to add it has a melting hi volume and pressure oil pump.
I do not have an dyno time, I never turned the boost up past 16psi. please send me your phone number and I can text any video you would like.
also , im in Arizona but moving to Georgia in early November. motor can be shipped anywhere. call anytime, 602-339-9618
