Confused about different Heads
THEMADTYPH00N
Re: Confused about different Heads
Do the splayed heads actually work in the turbo applications? What kind of #'s do they flow?
Theres nothing about the splayed valve design that makes it undesirable for a turbo application. In fact from a performance stand point the splayed valve design is better in most every way. The enormous cost of getting those heads to work is why you don't see any of them. I've never seen any flow numbers myself and Mike Lee would probably be the person to ask. To my knowledge he is the only one to ever have one running in a Syty, or a turbocharged splayed valve V6 or that matter. What you essentially have there is a V6 big Block Chevy head. I would guess that head could be anywhere from 375 to 400+ cfm on the intake side & 250+ on the exhaust. Unless your looking to make 1400+ HP I wouldn't even consider them. Just look how fast Jamie Hacking has gone on an inline valve head. As an interesting side note these heads are still used by a few guys today in NHRA Competition Eliminator.
THEMADTYPH00N
The pressure in the exhaust manifold of a typical stock turbo set up, is about 2.5:1 (generalization) So for a stock SyTy I would expect to see pressure of about 35psi with an inlet pressure of 14psi. Race vehicle will approach 1:1 ratio. Most modified vehicles are probably in the 1.5-2:1 range. Just because their is more exhaust pressure than intake pressure doesn't mean significant amount of exhaust are in the intake. The exhaust stroke pushes out burnt exhaust out of the cylinder (which is creating cylinder pressure) and their is minimal overlap between when the exhaust and intake valve are open. For street Turbo motor this is one of the main reasons why larger lobe seperations are selected for turbo cams, to reduce the overlap.
Well said. The technology in the exhaust sides of turbos has come so far now you'll see race vehicles that run with almost no back pressure on the exhaust side. As a result camshaft specs are starting to look more & more like N/A cams and moving away from the wide LSA's with no over lap. You'd be surprised how hard some of the Outlaw 10.5 & ORTC turbo cars cam now.
Icarus-54
Donating Old Member
On the lil brodies,stock exhaust manifolds are no good as the #2 plug will touch the manifold.You could grind a notch there but you may be asking for trouble.Rpm sells headers for these heads(expensive),then you'll also need solid motor mounts,different steering shaft and valve covers.I know because I just did this conversion.
It's just a six
Super Member
Another thing to add,even if the cyl head does not flow well because of poor porting, valve job etc, but the ports are opened up, bigger port windows to allow more air to enter the engine, a turbo will shove/force the air through the engine.
It is not as critical as a naturally aspirated engine to have a proper valve job, correctly ported head to make more power.
Yes, if you have done a great valve job, ported done correctly & improvments shown on a bench flow ,you will make more power w/a forced inducted engine, as compared to a hack valve job & horrible porting done to cyl heads.
MRKING
New Parts for Old Trucks
Complete setups come up for sale every once in awhile . They are really not an option if you want to start fresh/new, way too expensive . I cant wait to share hp numbers or timeslips on my "bought not built" setup . ;) Dumping more money into the sy paused when the economy downshifted though or mine would be driving .
IIRC Mike Lee and the LSR Syclone are the only syty's to ever run these heads , both rwd . I thought i read Tom Ferrick has these on his 8sec ty but cannot find the thread i saw it posted in . Another rwd if so . i would like to confirm this yes or no if anyone speaks with or knows Tom personally .
Silly
Banned
Tom did not have them on his motor when I last spoke to him. Although he did have a boat load of stuff. Bunch was for sale years ago, no idea what's left if anything
turbodig
Brodix -8's/-10's: I believe the stock intake manifold can be modified to fit these. If you can order this head as a straight plug instead of an angle I've heard you can used stock exhaust manifolds, otherwise you need headers.
Sort of a "yes and no" on this. Yes, the straight plug heads will work with stock exhaust manifolds, but not what I'd call well. The plugs end up being so close to the manifolds that the wires burn frequently.
Not an ideal situation, and if you're ponying up for Brodies or any other head, you're probably looking for a solution that works better than this.
turbodig
I've seen this setup on a Comp-E Rail, ran 7.50 on a normally aspirated 6. Pretty impressive.
Only turbo app I've seen was the factory 'vette Falconer prototype.
These are big RPM heads... all out max HP territory.
turbodig
Vortec have either 10mm or 8mm screw in rocker threads. The 8mm thread are for using shaft mount rockers used on the later Vortec heads. Last I look their was not an off the shelf 10mm screw in stud that work with out using shims. You can drill either the 8mm or 10mm for typical SBC screw studs/rockers. (I use the factory vortec shaft mount rockers.) Your are correct about the non self aligning / guides /pushrod requirements.
Having done both, the self-align is a much better option, IMO. Once you get into the exotic heads that situation will change, but for L35s and Vortecs that you're not trying to spin above 6000, I'd stick with self-align.
sy#2716
SyTy 4 Life
I remember when he had the truck for sale and i went back and found the link.
I do not know what heads are on the motor that was in the truck but he list that he had a spare motor with splayed valve heads.
Here is the link.
http://www.syty.net/forums/showthread.php?t=61194
There are alot of options out there that can make good power prime example look what alex did with l35's and also vortecs. Also look at the stokes motors that ran in the 10's with l35s. Unless you you step up to the level of robert, hess, hacking, gerber, or bully then a factory cast head(vortec) will make HP up to say 700+hp. Look what Nolan has done with l35's and vortecs. The heads are pretty decent from the factory but as any of the big guys will tell you it will be all in the tune that makes the power and keeps everything together.
turbodig
Used to be that 1.2:1 TIP ratios were unheard of, but not anymore. There's a lot you can do with inlet and outlet nozzle technology.
Ty#365
BOOST LAUNCH KING
A few sets of these heads Ive run across have Titanium EXHAUST valves. That will work for a N/A application but they wont take the heat of a turbo motor. In your case Inconel would probably be the best choice.
What you REALLY need is some valves made from unobtanium.;)
bonesdmz
In Mother Russia Typhoon drives You!
Pls move this elsewhere, its kinda interesting thread.
