BMFB
Not to scale
(background of rant, just rebuilt motor, destroyed thrust bearing, pulled motor out, everything was installed correctly, builder says it has to be a converter)
I've been dwelling on this for a couple days now and I'm still not sure what do. I could just put in a converter and hope for the best that it was the issue, and in doing, also put me in good with my engine builder in case something bad does happen again (he said it had to be the issue, even though a local shop ok'ed the converter after an inspection), this is in my opinion, the very least I can get away with. The other possibility with the trans is that something did in fact go wrong with my front pump, and if it did, I would have to remove the tranny and at the bare minimum repair the front pump, by myself, or at a shop. Now, in the case of rebuilding the whole trans, I'm scared to have a local shop do it, because the way these trannys are setup is somewhat special, and not many shops have experiece/care. They would build it as they would a corvette trans and then when i break it say that i must have done something wrong, because there is no way my 'stupid truck' could have broken it with torque. my other options on rebuilds is to ship it to indiana and have RPM trans rebuild it, or to go balls out, and do it myself. I can see the idea that is doesn't add up that the trans is 'suddenly bad' after an engine rebuild. My engine builders been doing this for a few decades, and seems like a really honest guy, I have talked to him extencivly and he swears he has been through the engine and there was nothing wrong with its assembly, and even so, he is warrantying the labor of rebuilding it. He swears it had to have been something from the transmission pushing on the bearing.
All of those thoughts have been on my mind all day the last few days, writing them down kinda helps me think, hopefully this wasn't annoying to anyone, cause I know a few people have already heard it extencivly.
