Confused rant
BMFB
Not to scale
(background of rant, just rebuilt motor, destroyed thrust bearing, pulled motor out, everything was installed correctly, builder says it has to be a converter)
I've been dwelling on this for a couple days now and I'm still not sure what do. I could just put in a converter and hope for the best that it was the issue, and in doing, also put me in good with my engine builder in case something bad does happen again (he said it had to be the issue, even though a local shop ok'ed the converter after an inspection), this is in my opinion, the very least I can get away with. The other possibility with the trans is that something did in fact go wrong with my front pump, and if it did, I would have to remove the tranny and at the bare minimum repair the front pump, by myself, or at a shop. Now, in the case of rebuilding the whole trans, I'm scared to have a local shop do it, because the way these trannys are setup is somewhat special, and not many shops have experiece/care. They would build it as they would a corvette trans and then when i break it say that i must have done something wrong, because there is no way my 'stupid truck' could have broken it with torque. my other options on rebuilds is to ship it to indiana and have RPM trans rebuild it, or to go balls out, and do it myself. I can see the idea that is doesn't add up that the trans is 'suddenly bad' after an engine rebuild. My engine builders been doing this for a few decades, and seems like a really honest guy, I have talked to him extencivly and he swears he has been through the engine and there was nothing wrong with its assembly, and even so, he is warrantying the labor of rebuilding it. He swears it had to have been something from the transmission pushing on the bearing.
All of those thoughts have been on my mind all day the last few days, writing them down kinda helps me think, hopefully this wasn't annoying to anyone, cause I know a few people have already heard it extencivly.
Big Mike
Re: Confused rant
I would also change the radiator out and clean the oil lines or get new you do not want to use that oil cooler again after that has happened. Is this the same converter and trans used with old motor? What happened to old motor?
BMFB
Not to scale
Re: Confused rant
with the last motor (same, rebuilt motor) I removed the oil cooler and cleaned all of the oil lines to the filter and turbo. i will have to do this again. Yes it is the same converter and trans, the precious motor died to a #1 main goin gout, due to a broken oil pump spring.
After this rant, adn reading a few times I decided what i think my best coarse of action is
Replace converter with a hughs or..something with a similar stall to stock, this will make by engine builder happy and continue with his warranty.
Put motor in carefully, making sure not to install TC wrong (didn't the first time, but added for good measure)
as soon as oil pressure is up and motor is running ok, trailer it to a local reputable tranny shop and have them check it for proper pressures ect to make sure the pump is ok.
go from there.
thank you for letting me post this
WyoSyclone
Re: Confused rant
GM says you have to get a new cooler, not just clean it out. As it heats up small particles will dislodge and destroy the new motor.
Ty 1885
Re: Confused rant
1) Make sure the tc is in ALL the way in on the tranny!
2) Make sure you put flexplate on right.
3) Make sure you have enought clearence between flexplate and tc !!! (3/8 inch i think)
I seen some people did not check these things, had the same problems that you are having.
P.S Just wondering how did the tranny shop checked your tc ? Did they open it up ?
It is very hard to tell if the tc had bolloned. If your going to get a new tc, make sure it has antibolloing plates on it!
KBowman
Re: Confused rant
Was it only one side of the thrust bearing worn out? If so then I agree with this reply above..had to be pushing against the crank to do that. #3 is the deal. Could be caused by #1 or #2
BMFB
Not to scale
Re: Confused rant
I know, but before I installed I checked those things, although I went with 1 inch in from the bell housing as a referance as well. I did not install it incorrectly, I know that mistakes happen, but I made sure before I bolted it together.
