Considering L35 swap
MoJo
Re: Considering L35 swap
These had screw in studs. My machinist thought that a good rebuild would cost around $600. I see that you still can buy 181 heads on ebay for $300 that are rebuilt. Do you think if they were magnifluxed with new springs and valves they would be ok,it doesn't say if they were. What about valve guides? Don't they put bronze ones in or something. My machinist said them and if the seats need to be changed is where the cost would be.What bothers me is that the ones on ebay say if you disassemble to inspect them it voids the warranty.
It is just a crap shoot when you buy anything on e-bay. You can buy unfinished heads on e-bay cheaper and have the work done by a machinist that you know is knowledgeable.. I would not pay extra for a pair of heads if the warranty is voided if I take them apart for inspection. Of course, I understand the seller's concern.
The stock 4.3L heads have valve guides will not accept a camshaft with more than .450" valve lift. We machined the valve guides on my "064" heads .160" down to clear the Comp Cams seals and the Comp Cams camshaft with .500" valve lift. Install K-line Bronze Bullet interrupted spiral valve guide liners with .0015" I and .002" E valve stem clearance and machine the guides .530" OD for Comp Cams 503 positive stop valve seals. We installed new Ferrea valves and the exhaust valves were 1.600" OD mainly to get a new valve seat. We left the intake valve 1.94" OD because the seats were good. You gain nothing below 6000 RPM with 2.02" intake valves especially if the valve throats are not enlarged to 85% of the valve size. . The flow balance is optimum with 1.94" intake and 1.600" exhaust valves.
We installed ARP 100-7201 rocker studs but changed them to SB Chevy ARP 134-7101 rocker studs for better adjustment geometry using self aligning, narrow body roller rocker arms. In order to do that, you must drill out the 10MM stud holes in the heads and install 7/16-14 TimeSerts with red Locktite to fit ARP 134-7101 rocker studs. .
Throws
wildphil
I Love My Ty's
My L35's should be done in the next week or so. I'm anxious to see where the price comes in on them.
For those looking for L35's, here's a link to a spreadsheet I've been working on for a few years now trying to document all the differences in LB4/L35/Vortec casting #'s.
http://r.b5z.net/i/u/10053520/f/4.3_Cylinder_head_application_guide.pdf
and where I host it on my website...
http://zddppluscentral.com/faq
That's cool your getting your heads. That is pretty exciting.
V6 Kompressor
If you want to go with a bigger cam and/or 1.6 rockers, you can use longer valves and beehive ls style springs. I used the GM beehives for a z06, they used to be yellow in color. I used comp cams retainers for the conversion. I think i have some pics of the heads in the sy/ty conversion section of the last set I did for the El- Caphoon. I used 95 L35 heads and went from 10mm to 7/16 threads like was suggested by mojo and used the crane gold self align rockers. I was able to use the stock teflon valve seals, but was going to change over to pc style if needed for retainer to seal clearance if needed. Using the good gm valve springs kept the cost down and they gave me room for about .575" lift if i wanted it.
URL=http://s894.photobucket.com/albums/ac143/Dam-Electrician/El%20Camino/?action=view&current=0607001748.jpg]
[/URL]
Couger1968
Dazed and Confused
Thanks for all the info it really helps. The head document is very useful. I never knew anything about the guide problems with a high lift cam. The one I am going to use is small enough not to cause problems, but I may upgrade some time down the line. Do all the heads have the same size valves?
MoJo
[/URL]
GM 12586484 are the yellow LS6 beehive valve springs and come in a set of 16.
GM 12499224 are the blue LS6 beehive valve springs and come one to a package.
Otherwise they are the same valve springs. ,
I purchased one GM 12586484 (yellow) valve spring to check the fit my heads and the spring was .845" ID at the bottom. Those springs will not fit the valve spring locator boss if it is .880" OD like is found on some 1988-up Chevy V8/V6 Vortec heads. I could not find a cutter that will cut the spring locator boss to fit .845" ID valve springs. That is why we used Comp Cams 26918 beehive valve springs that are .885" ID at the bottom. However, they are 1.310" OD at the bottom so you must cut the spring pockets at least .060" larger in in diameter. That is not a problem because there are all kinds of spring seat cutters for doing that work. Anyway, the spring seat pocket fit needs to be checked for sure before you buy a full set of springs from GM because GM does not provide the ID and OD of those springs. GM expects the customer to use those springs on the heads that they were designed for.
We started to use + .100" long Ferrea 5.010" long valves but we determined that ARP rocker studs were too short for those valves. My machinist had plenty of the Ferrea 4.910" valve in stock so we used those and longer SB Chevy V8 ARP 134-7101 rocker studs for better roller rocker arm adjustment. The SB Chevy ARP 134-7101 studs are .220" longer . However, the base threads are 7/16"-14 so you must drill out the 10MM threads in the heads and install 7/16"-14 TimeSerts with red Loctite. . Even the longer studs were too short so we added ARP 200-8512 washers that are .120" thick. The Comp Cams 875 reduced travel roller lifters helped with the limited rocker arm adjustment since the preload on those lifters is only .004" or 1/8 turn after zero preload. . .
Couger1968
Dazed and Confused
I ordered 10238181 heads. He said that they will have screw in studs,new factory valves and springs ,but are not adjustable Will the ARP 100-7201 be a direct replacement to fix them or will I want to switch to SB Chevy ARP 134-7101 right away. Thanks
wildphil
I Love My Ty's
The ARP studs are a little short. But you can put guide plates under them and they will work. I had self aligning rocker arms. So I trimmed the guide plates to clear the push rods.
Or you can pay a machinist to modify your heads and use longer SBC studs.
Either way works. The ARP and guide plate was a cheaper route for me. So I went with that.
Couger1968
Dazed and Confused
What about nuts ARP said (These rocker arm studs are designed to be used with Perma-Loc adjusters (not for use with OEM-style, self-locking nuts).
MoJo
You must convert to fully adjustable valve train only if you have a high lift aftermarket high performance camshaft because the stock "net-lash" 20 lb. torque adjustment method will not set the correct lifter preload unless you experiment with different length push rods. That is because aftermarket high lift camshafts have smaller cam lobe base circles. .If you have a stock or stock replacement camshaft, the net-lash rocker arm studs on L35 heads will work fine.
If you use one ARP 200-8512 hardened washer under the ARP 100-7201 rocker stud, the rocker stud will still be too short . The ARP 100-7201 rocker studs are .360" too short for poly-lock rocker nuts and full roller rocker arms. All ARP washers are 120" thick and you would need three under each rocker stud. If you use three washers, the lower thread in the heads will be shortened from .580" to .220" which is risky and can pull out. . If you use ARP 134-7101 SB Chevy V8 rocker studs with 7/16-14 TimeSerts in the heads, you will need only one ARP 200-8512 washer under each stud . The ARP 134-7101 studs are .220" longer than the ARP 100-7201 studs so you will need one .120" thick washer to get close enough length for correct lifter preload adjustment with poly locks and full roller rocker arms. One alternative is to experiment with Comp Cams 1417-12 roller tip, ball pivot rocker arms with the ARP-100-7201 rocker studs. . I have not personally tried it but I heard at the "barber shop" that those rocker arms and the ARP 100-7201 studs will allow you to set the lifter preload correctly.
Unfortunately, The ARP 100-7201 rocker arm studs were designed for the Chevy 2.8L V6. The only thing the studs used in the 2.8L V6 heads have in common with the studs in the 4.3L L35 heads is the 10mm threads.
Couger1968
Dazed and Confused
Are the ARP 100-7221 just way to long. I am running an aftermarket cam and lifter, but everything else is oem. Can I use my factory nut or do I have to use something different.
MoJo
Before we installed the ARP 135-7101 studs and the TimeSerts, I purchased "one" ARP 100-7221 stud for comparison. They are exactly the same stud as the ARP 100-7201 studs except the 100-7221 studs come in a package of two instead of a package of 16. .Sometimes the data in the Summit catalogs is not correct or the parts are packaged.incorrectly.
You must have some sort of locking feature on the rocker arms nuts.
You can use factory rocker nut only if you use the factory net-lash rocker studs. Those nuts have tapered seats for the locking feature. They cannot be use with an high lift aftermarket camshaft.
The adjustment thread on the ARP studs are 3/8-24. You can use early SB Chevy 3/8-24 prevailing torque rocker nuts on the ARP studs. The prevailing torque threads is the locking feature. They are for "set once and forget" because the threads in the prevailing torque nut will eat up the threads on the rocker stud if they are readjusted a few times. In order to use those nuts, you better be right the first time you adjust the lifter preload.
Of all the various options, I feel like using the ARP 100-7201 rocker studs with one ARP 200-8512 washer under each stud will enable you to use Comp Cams 1417-12 roller tip, ball pivot, rocker arms. That option is the most economical way to use an aftermarket high lift camshaft. However, in my opinion, the best and as usual, the most expensive option, would be to use the ARP 134-7101 studs, TimeSert (BigSert) 57611 ( 7/16-14 x .600" ) with one washer and Comp Cams 1015-12 full roller rocker arms. .The TimeSerts (BigSerts) cost about $50 (the installation kit cost $80) and machine shop labor for a total of about $150. .
Couger1968
Dazed and Confused
I have another dumb question I thought my truck had adjustable rockers from factory. They look like they are compared to my 351 cleveland ,which is net lash with a pedestal, but my truck doesn't have any locks. I may be wrong since my only comparison I have dealt with is the cleveland.
MoJo
The factory fully adjustable lifter pre-load rocker studs used in 4.3L heads are pressed in. The factory non-adjustable (net-lash) lifter pre-load studs used in 4.3L (L35) heads are screw-in.
Non -adjustable means that you tighten the rocker nuts to 20 ft./lb torque and the lifter pre-load is set. The non-adjustable rocker arm nuts and rocker studs have tapered seats to lock them together when the torque on the nuts reaches 20 lb/ft. For that type locking method to work, the distance between the rocker nut and the cam lobe base circle must be the exact factory specification. That is why net-lash rocker nuts and studs can only e used with a stock or stock replacement camshaft that has the same factory cam lobe base circle diameter. If the cam lobe is smaller in diameter, such as those found on high lift camshafts, it will throw off the 20 lb/ft torque locking method.when setting the lifter pre-load. The hydraulic lifter plunger pre-load setting, which is half-travel, must have some way of locking the pre-load in position. .
If an aftermarket high lift camshaft is used which has a smaller cam lobe base circle diameter, the factory 20 lb. torque method of locking the rocker nuts will not work. In that case, prevailing torque nuts (nuts with oval threads) must be used or poly-lock nuts with full roller rocker arms must be used.
Couger1968
Dazed and Confused
So it looks like my truck had pressed in adjustable rockers from factory. Did it have the prevailing torque nuts on it since there was no locks? What is the chance that using my LB4 rockers and push rods with my mild cam that the net lash set up of the L35 will work. Can I shim the factory screw in stud to compensate? I have comp cam lifters that didn't need much preload I think like 1/2 a turn if I remember. Trying to keep cost down and haven't received all my parts yet.
MoJo
Pressed in studs have prevailing torque adjustment nuts "Set 'em and forget 'em". No readjustments should be done with those because repeated adjustment will cause the nuts to ruin the threads on the studs.
The stock base circle on LB4 camshafts is 1.380" intake and 1.335" exhaust. They are different because the stock intake and exhaust valves are different lengths and that is because the exhaust valve springs have valve rotators. The cam lobes on the Comp camshaft are symmetrical and they have smaller base circles,. Therefore the 20 lb./ ft torque method of locking the pre-load settings will not work and the 3/8"-24 prevailing torque locking nuts will not fit the L35 net-lash screw in rocker arm studs.
To use the Comp camshaft, you must install ARP rocker studs, self aligning full roller rockers and poly-lock nuts or Comp self aligning roller tip rockers and use new prevailing torque locking nuts. The stock rocker arms are self aligning and will not work with the integral push rod alignment holes in the L35 heads.To use self-aligning rocker arms with L35 heads, the integral push rod holes in the heads must be opened up with a 7/16" reamer. A 1/2" reamer would be better but due to the close proximity of the intake port wall makes using a larger reamer somewhat risky. The push rod hole is about .333" diameter and larger .438" diameter hole appears to be enough clearance. A 7/16" reamer worked on my L35 heads.
You can only use one of the three methods of upper push rod alignment. That is because of misalignment of more than one method and the possibility of excessive push rod wear and binding. The three methods of push rod alignment are: 1) self aligning rocker arms; 2) alignment plates under the rocker studs; 3) integral push rod alignment holes in the heads. You cannot use a combination of any of the three methods. The lower part of the push rod is held in alignment by the push rod seat in the lifters.
Couger1968
Dazed and Confused
I have a crane cam. I will have to find the base circle specs. I didn't know I would have to change my rockers,when I asked what all was involved and no one said anything about that. I thought these heads were more of a direct bolt on,change the studs and go.
