Re: Considering L35 swap
It is just a crap shoot when you buy anything on e-bay. You can buy unfinished heads on e-bay cheaper and have the work done by a machinist that you know is knowledgeable.. I would not pay extra for a pair of heads if the warranty is voided if I take them apart for inspection. Of course, I understand the seller's concern.
The stock 4.3L heads have valve guides will not accept a camshaft with more than .450" valve lift. We machined the valve guides on my "064" heads .160" down to clear the Comp Cams seals and the Comp Cams camshaft with .500" valve lift. Install K-line Bronze Bullet interrupted spiral valve guide liners with .0015" I and .002" E valve stem clearance and machine the guides .530" OD for Comp Cams 503 positive stop valve seals. We installed new Ferrea valves and the exhaust valves were 1.600" OD mainly to get a new valve seat. We left the intake valve 1.94" OD because the seats were good. You gain nothing below 6000 RPM with 2.02" intake valves especially if the valve throats are not enlarged to 85% of the valve size. . The flow balance is optimum with 1.94" intake and 1.600" exhaust valves.
We installed ARP 100-7201 rocker studs but changed them to SB Chevy ARP 134-7101 rocker studs for better adjustment geometry using self aligning, narrow body roller rocker arms. In order to do that, you must drill out the 10MM stud holes in the heads and install 7/16-14 TimeSerts with red Locktite to fit ARP 134-7101 rocker studs. .
These had screw in studs. My machinist thought that a good rebuild would cost around $600. I see that you still can buy 181 heads on ebay for $300 that are rebuilt. Do you think if they were magnifluxed with new springs and valves they would be ok,it doesn't say if they were. What about valve guides? Don't they put bronze ones in or something. My machinist said them and if the seats need to be changed is where the cost would be.What bothers me is that the ones on ebay say if you disassemble to inspect them it voids the warranty.
