Contemplating stand alone system
TYTILIDIE
METH HEAD
Hey everyone. Since the wife's Ty's trans took a dump and I transplanted my fresh fully built 700 in to hers, I have been giving very serious thought to going with the 4l80. Since I still have a lot of work to do on my Ty, I figure it is just sitting there anyway and may be a good time for this.
I have come up with three ways I can do this but am really not sure which one is the best way.
OPTION 1- Run whatever ECM comes out with the junkyard tranny. I would have to severely modify the harness which doesn't bother me, find a bin for the new ecm and tune it separately. This would be by far the cheapest route. I would pay about $3,500 total but would be a ton of work. Good thing is that if the ECM were to go bad I can run to Autozone and get a new one for $75
OPTION 2-Do everything the same only use the TCi controller. This would cost me approximately $4,000 to do. My problem with that set up is that I don't know what I would do if the controller took a dump on me. I would be pissed!!!
Option 3-Run BS3, XFi, etc. Problem here is that it would cost me about $6,000.00 to do everything and I would have it all done in one shot tuning wise. Again failure of the controller scares me here. What kind of warranty do you get with these things? Is it really worth $2,800??
I think that at this point my build can justify option 3 but just costs a bunch. For you guys that have done any of these, please chime in and give your experience or opinion. TIA.
Foot Performance
Re: Contemplating stand alone system
If your running the v6 still pretty sure you are I think running a factory ECM would be a giant PITA be cause you are going to have to wire in engine inputs that may or may not match up (information/voltage) from LSx to out 4.3 due to older/diffrent sensors plus I don't know how the stock controller would act with out things like a MAF sensor hooked up it may go into a limp setting
Unless there is some way to modify the programing in a stock gm ECM in a way to fix these problems which there maybe and I am just unaware I think a stand alone controller would be the easiest most cost effective way
TYTILIDIE
METH HEAD
Wiring up a stock ECM from the donor truck really doesn't scare me. I searched the other night high and low for bins for early 90's 4l80 trucks and found nothing. That is what scares me. I think if I could get that idea going it could be very good alternative to people on a budget as I would document the whole thing with detailed pictures.
Now the reason I am thinking about BS3 or XFi is simply for the possibility of easier tuning. I assume they both can control the 80 but think I read that XFi does not? My main discouragement from XFi or BS3 is if the unit goes bad. I think I don't want to use the stand alone trans controller. But still have yet to make up my mind. I have time for that:lol:
Ry368
one mile = 5280 feet
My buddy did the Compushift for a 4L80 swap into his 6 speed Zr1 and it worked well.
mattw
I already did document the whole thing with pictures.. Problem is my web server crashed a few days ago and I don't have a way to host it.. Maybe I'll see if Renz can host it on his server tomorrow. I've got the bins that you need as well.
Beavis
Still plays with trucks
If you use 2 seperate systems, if one fails the other is ok and won't interfear with the it. :2cents:
Matt has bins for the GM ecm route, i can dig up the bin from Jeremy's and Daron's truck. I have done the GM route and once done it really works very well.
PCS makes a tune via dial trans controller now also. (they make the TCI unit and paint them red).
leadfoot
OPTION 4: 0411 PCM. Cheap, available, tunable (including trans) w /faster processer.
Need a 2001+ 4.3 harness. You would have to add a crank sensor and change/modify the timing cover, add a newer distributor w/cam sensor (PnP), retrofit the knock sensor (two wire vs one), make an injector harness and switch over a few connectors.
Poconoejoe is converting his Sy to 0411 PCM. He may have found an even better harness off of a FWD V6.
Joe?
Not knowing much about the 0411 how does it do for boost?
leadfoot
Depending on the software used ( HP Tuners, EFI Live etc) you can run them on Speed Density or Mass Air Flow. (that in itself is a debate)
The 0411 is gaining in popularity as the cost is reasonable in comparison to BS3, XFI and they are fully tunable.
UR50SLO
V6+2=LSXCamaro
If you don't mind shifting you can use this:
Using Plug and Play Technology Convert any Gm Computer Controlled Electronic Transmission into a full Manual Shift Transmission Without Having to Remove the Pan or Valve body.
Price $295.00
BS3 has the controller built in.. I don't beleive XFI does. At least our version of XFI does not.
The 411PCM can be used and can be 2bar MAP tuned or MAF. You'll need to still do work and programming for the 4l80E to work since the 4L60E was the transmission it was mated to from the factory. As they said you'd need a front cover with Crank sensor and newer dist. with cam sensor in it.
Hope that helps,
Scott~
Quickstop [UK]
Combating adversyty.
As innovative as these alternatives are, how much will the costs be?
$295 for the Moroso thing.
The 411 PCM - say $50
The dis with crank signal - $50 min
The front cover with timing signal etc. - $20-50?
$450...
You're not shy of the cost of the TCI controller and you've got a heck of a lot less work in front of you. I might be wrong....
FWIW PCS, who made my controller, were AWESOME with their customer support. They sent a new unit via FEDEX overnight to the UK with a new harness as well as soon as I thought it might be bad. Turns out it was actually the valve body.
With that kind of service I'd take the (very small) risk on the TCI/PCS unit.
mattw
I was able to load the 80e bin on an ecm from a CPI s10 that orginally came with a 60e(very plentiful at u-pull-it-yards for ~$20). I grabbed the harness from the same vehicle as it has all of the needed connectors($5 misc charge). You need an adapter & chip for the ECM(~$30 from moates). All of this plus a few hours time making the harness and you are good to go.. So for $55ish you can have a half decent 80e controller tunable with Tuner Pro...
I haven't heard back from Renz but the webpage I put together walks you right through it...
mattw
Personal Web Space to the rescue...
http://home.comcast.net/~mattjw76/4L80E/
EDIT: I made that how-to a few years ago.. After re-reading it I'm thinking it really needs a final wiring diagram of the harness that needs to be made.. I'll see if I can throw one together in the next week or so..
Foot Performance
My bad I forgot all about the older ECMs everytime I think 80e I just think 99 up controller but if you I think I have a 0411 PCM at the shop if you want one to mess with
