crazy high idle after tune-up?
Frank
Tuned up the Ty this weekend because wires were shot (about 3000 miles on Accel 9000 extremes; resistence of .85-1.45 (and #6 was just plain shot after laying up against my downpipe). Used stock plugs, Conrad cap, ATR wires and DEI boot protectors this time. Incidentally replaced vac. lines (with the GP kit) while I was at it. The Ty's idle has hunted when cold for years now. Did same when I started it after the tune-up BUT on one occassion it increased up to about 2000 rpm and in a few seconds settled down to "normal". Thought I saw check engine light go on for a split second. I then remembered that had fp set at 55 (my fault, took to track two weeks ago, set it high after my first run thinking that it would help because truck was obviously running bad and forgot to reset it). Reset FP to 45. Seemed to run OK after I reset FP and took it around the block a couple of times before putting it back into the garage although check engine light could have flashed on another split second (I may be paranoid). Have not had time to diacom it yet. Hopefully will get to it in the next couple of days.
Any comments/theories on why rpm shot up that much during idle. Happen to anyone else?
Thanks
Frank
'92 Ty
turbodig
Sounds like an intermittent vacuum leak to me....
Either that, or your chip is loose and the ECM is going into backup fuel mode.
Later,
Dig
'91 Sy- 12.08@110 | Full factory mufflers.
Frank
Have not fixed problem yet but getting closer. Replaced 3 bar and chip with 2 bar and atr chip. Doesn't stall out and check engine light isn't flashing now. Idle hunting not as severe now but more than I can live with. Boost guage at idle indicates vacuum decreasing and then increasing constantly. Could be some kind of vacuum problem. Not vac. hoses. Maybe intake manifold gasket leak Hear hissing noise near front of engine on driver's side. I will try to work on it this weekend.
Thanks for your replies.
Frank
Cleveland, OH
'92 Ty
