Pittman
Well I got my truck all back together after a vortec install and it sounds awsome with the new headers, cam, heads. Afterwards I notices a very small coolant leak. By very small I mean a drip every 5 minutes or so. After about an hour with a mirror and light I found it. I have a hairline crack on the front of my intake. I think it should be easy to weld and resurface so im not worried about it. I cant figure out how it happened. Intake bolts should be torqued <20lbs right? like about 15-18 or so. Jerry McCoy gave me a gasket set that has a vortec gasket and an old style gasket glued together. SO they sit pretty high. What torque sequence are you guys using on this??? Any other intake gasket options, that are better??
