Datalogging errors and miscommunications.....
Sy769
I am really getting sick of this. I lose com at WOT or close enough to it to be in boost.
* Exhibit A*
I've fought with my truck (#769) over it for years. Added mutiple extra grounds and a capacitor to the ignition power wire that feeds the coil. That seemed to help the disconnect but I still get errors. As a note when I connect the MSD 6 I get errors at idle and cruise which tells me ignition noise is behind this. As I get into bost ignition is strained therefore more noise, or leakage??? :?
I've changed laptops to a brand new one that has a serial port. Still no change. Also it links right up so I don't think that the ALDL timing is a issue. If this was a NA vehicle I doubt I would have issues.
*Exhibit B*
Last night Don and I took out Sy112 for a test and anything above 10psi I would get ton of errors and then a disconnect. Real PITA to try to diagnose anything with the datalogger losing connect.
*Exhibit C*
Rudy Valdez's Ty 1450. Same kind of problem lately. He FINALLY bought his own laptop and cable. :wink: It is the same brand cable as mine (AMK)
What do these three trucks have in common? MSD 8.5 wires. Conrad cap and stock coil. ECM's in the glovebox. Ultimate on Don's and Rudys and a Hypertech adapter holding my prom.
What do they not have in common?
1.Mine has no IC pump. A alky kit based on the Shurflo pump
2.Don's has a SMC kit which is currently dead so I doubt that is a issue and a Johnson pump running the IC
3.Rudy's has no IC pump or alky and he has a A2A.
So do any of you datalog with no issues such as a high rate of errors and disconnects? Do you use MSD 8.5?
I just have a feeling the MSD wires are too noisy or something is causing a noisy electrical system and causing issues.
That or the cables from AMK are susceptible to noise.
Ideas? Comment? Discussion?
AlaskaTy
I've been having tons of error messeges on datamaster lately. I'm going to run it today and see what happens (I have the stock chip in now). If I still get errors, I'm going to disconnect my MSD 6A and see if that clears it up, looks like you've already checked that though. I'm running Taylor's so I can't help you with the wires.
gmcturbo
Re: Datalogging errors and miscommunications.....
i use msd's - i also use an akm cable with a laptop w/ serial port (new) and am havein disconnect and data err probs all over the place. its annoying to say the least.
mike
Typhoon #1133
i also use an akm cable with a laptop w/ serial port . i have had problems with it disconnecting and errors since day 1. i have tried different laptops and also got a new cable from akm. nothing has helped. i cleaned all my grounds also. if you ever figure this out i would like to know. I have used Taylor and MSD. no change in problem. i also have a new coil and coil wire. It has done this with any chip i had in it. and higher the boost the worse it gets. i never have any problems at cruise.
Sy769
At least I am not alone :)
I wonder if it is something inherit to the AKM cable?
Does anyone have a non AKM cable that dataloggs well? Especially for those of you with broken trucks.
I would pay for shipping to test it on these trucks to check for differences.
Loeryder
Patrick, PM me your addy.
I have 2 cables sitting here, you can borrow one till nats and just give it back to me there.
Both are not akm and I have never had any disconnects.
To some extent the errors and disconnects are also ignition noise related.
My setup is closer to Keith's with the taylor spiro pros ngk plugs conrad and running smc alky.
All I ever get is a DRP error for one frame then it goes back to normal. DRP = Distributor Reference Pulse
I think that is related to the reman'd distributor the prev owner installed.
The only way to know its done right is to do it again yourself.
Another thing to check is that the aldl terminals are still nice n tight.
After lots of plugging and unplugging as much as we hook up the terminals get bored out like a bitch in the french quarter.
I used a pick set to give all the clips a tweak so it makes a good connection.
Sy769
quote]
:lol: Lynn was looking over my shoulder and laughing her ass off when she read that.
Thanks Jas'
THEMADTYPH00N
I have an AKM cabel and have this same problem. This is what I think. There are some cable that have an adapter that plugs into the cigarette lighter to power the connection. The AKM does not. So when you start to get into the throttle the electrical system gets loaded up and the ECM or computer cant provide enough voltage to keep the connection alive. Ive seen a couple people with cables that are powered and never heard anything from them about communication problems.
Sy769
That is weird. My AKM cable has a plug for the cig lighter. :-?
Tim Zapoluch
I know this might sound like (and be) a royal pain in the ass, but, have you tried shielding the plug wires by wrapping them in aluminum foil? they have to be grounded at one end only. Maybe try wrapping the wire between the aldl connector and the laptop. once again, ground one end only to avoid ground loops. if it is indeeed an induced signal, this should help. also could try a small snap on ferrite inductor in the power wire. you can get one from any old computer device.
Hope this helps.
Tim Zapoluch
leroy
I haven't looked at the schematics for awhile, but I was under the impression the cables without a cigarette adapter were powered by the laptop. Cables powered by the cigarette lighter adapter would lose voltage at higher rpms.
My cable does not have a power adapter and works okay.
HTH,
Jim
