Datalogging help!
Re: Datalogging help!
That log shows nothing. When I open it with datamaster.
Fix all the codes first and then worry about getting rid of detonation. You may fix both at once. Do you know what codes you are getting? Do you know where to look them all up?
Bustedsm
Numbered Car Crazy
Here is a quick screenshot then....showing the codes highlighted in green and the spark retard in the middle obviously.
Ty's 93-TYPHOON
xxx BIG xxx
i am still new to these but how in the world are you showing 2 different readings. rpms and everything dont match. when i use my datamaster they are alwaays the same. Spark retard 0.0 / 7.2?
this is not any help for you but it surprised me. hope you figure out whats what.
Bustedsm
Numbered Car Crazy
Anyone else have any idea why I'm throwing eleventy billion codes?
WyoSyclone
Any time you move your mouse over the graph section, it will change the values in the chart at the right of the screen, regardless of where the bar is... whenever you're capturing a screen shot you need to make sure your mouse doesn't cross the graph or it will change those values at right... all the information in the upper fields isn't affected.
Bustedsm
Numbered Car Crazy
I do need to order a boost gauge, and is it possible to feed an oil pressure gauge off the unused port on the oil filter relocation near the intake tube? I don't know the size of it though...
Bustedsm
Numbered Car Crazy
So the car is running 11-12lbs of boost confirmed with an actual boost gauge.
Bustedsm
Numbered Car Crazy
So I realized F1 was for help, but what is the possibility my ECU isn't grounded and is throwing all of these codes?
WyoSyclone
Start DataMaster, and hit F1.
Hit the search tab, then type in 'DTC codes'
You'll find the answer you seek.
OK..... what Dig was trying to hint at, is that the 'green' DTC's in that table aren't thrown codes.... they're only a problem if they're colored red...
go back and hit 'F1' and type DTC into the search button.... it gives a good explanation.
Bustedsm
Numbered Car Crazy
Oooh, I understand. I'll download the program here on my work computer because I run mine off Vista at home, so no F1 help from Datamaster :(
EDIT: Ah, now I completely understand. Those green ones are just that which can be recorded and shown. Go figure, I was freaking out over nothing!
