CalgarySS
1000 miles and counting..
Gentlemen,
I have been having a boost limiting issue lately...
Stock truck with a cat and a dumped exhaust with a turn down under the bed. MSD box, Stock fuel pump, stock crossover tube, stock fuel regulator.
This first file was a single run that I had a stuck flapper for the first second or so. After PB Blasting it and adding some graphite lube it eventually came unstuck. This was the last run that it showed up.
I am running 1/2 tank of C-16. I assume that the remaining knock is false or my plugs need changing, even though they only have a few hundred miles on iridiums.
The code that the truck was throwing during this run was 42 and was cleared later that day by pulling the ECM fuses.
http://www.mediafire.com/?23dyuh6hlf206yo
The second file has two runs on it, one from a street start, the second with a boost launch. It was slower than usual to build boost and did not get up to the15psi that I normally launch at. Same 42 code.
http://www.mediafire.com/?1cji6umayaanxdb
Last file with race chip, still low boost, real knock? I cleared the codes for this run.
http://www.mediafire.com/?gv55td83tth0hdf
After the Nats this year I will be doing some work on the truck. 20g and matched converter, meth, walbro,afpr etc.
I just want to have it run it's best one more time this weekend.
