Re: datamaster problem
to see your trucks knock and settings you have to be recording if im not mistaken. well either way you go to file and select record aldl data, this will bring up a smaller screen which is the serial data acquisition screen. once there select file and then open, make a name for your run and select a folder to save it too then press ok. then whenever you want to start your recording select start from teh serial data acquisition screen (make sure the top of the screen says "record on" if not just press the "rec on/off" button to change it) then once your done with what you want to record press stop save it and close the serial data acquisition screen ONLY. this will put you in playback mode. hope this helps, have fun!
