boosteds10
Finally Fixed
Im seeing something funny with my typhoon. When I put the pedal to the floor the boost is quick to rise to 15psi, then drops down to 10psi and slowly climbs and holds at 15. If I gradually inclrease the throttle, the truck will continuously ramp up and hold to 15psi with almost no drop at all.
So I started looking at the datamaster logs and im looking at this value "BoostTgtPSIg" Im assuming this is what the ecu is telling the boost solenoid to make. Well when the WOT run hits 15psi, the boost target psi is still around 9.5. Im gonna guess that this is why I see the boost drop. why is this happening? On the slower increase to WOT the target psi rises almost the same speed as boost pressure and that would explain the second scenario.
I started to get into $59 a little bit, still dont have the cables but im looking at the stock tune from the code $59 forum. I look at the target psi boost table in that and its his peak psi all the way across the board. Is this safe? Will this solve my problem?
Thanks guys and sorry for the novel.
