Mike said:I just made my first datamaster run today and I was wondering if someone could take a look at it just to make sure its running the way it should be. I dont know how to post the file but I could e-mail it to anyone willing to take a look.
Thanks,
Mike
ViciousV6 said:How is the truck running. Popped a head gasket last weekend on the dyno, so the motor is coming out in the next 30 mins and gonna go through it and maybe change the cam and few other small things and then stick it back together and send it again.
If i am taking ti out, gotta check the bearings, and wear and tear on the motor since everything is all right.
Talk to you soon.
Ralph
91blazins10 said:Well your truck seems to be running pretty well for the most part, I would work on bringing down the intake temps alot, they peaked at 211. I think this is the reason it has some knock, also you need to record a nice wide open throttle pull with datamaster.
Mike said:Thanks. What are some ways that i could bring down the intake temps? I'll get a WOT run tomorrow and e-mail it to you.
Okay. Good luck with your truck. Will it be up and running by the hooters meet?ViciousV6 said:Meth injection, or Air 2 Air Intercooler, or auxilary Intercooler to help out the stock one, also make sure that your intercooler pump is working, Garth truck isn't working and his Intake air temp are lower than that on a noraml basis. Maybe if you haven't flush out the intercooler system and freshen with new fluids.
Yea my motor is out and hopefully willl drop it off at the machine shop 2morrow to go through it and maybe stick new bearings in and check all the bolt stretch and new cometics and then new cam from Harry Anderson and back into the truck for Hooters and Track Rental day.
Ralph
Mike said:Okay. Good luck with your truck. Will it be up and running by the hooters meet?
