SyTyAddict
I have been having trouble with knock across the board from idle in park to WOT. Today I bought another knock sensor and moved it to the front of the lower intake, the knock continued with little to no change. I pulled it back out and put one wrap of teflon tape around the threads and torqued it the 12ft lbs instead of 14. It continues to show knock at idle and with slight increase in tps, but it disappears after 1400-1500 rpms. The motor has headers, crane gold roller rockers, and forged pistons; I think the knock sensor is picking up one or several of these things.
What I'm thinking is to make the ecm ignore the knock sensor below roughly 1600 rpm, and hopefully it continues to not show knock above that number. It does show a little knock as the throttle transitions but it is very slight and short lived, it is also gone with the throttle held steady. Does anyone see a problem with this, such as the sensor being desensitized too much? I was trying to chase down these issues before I put my code59 stuff on it.
Thanks
Thanks
