Distrib. Being Off
SY2455
70's Veteran
i'll try the 180* thing, however than then moves me far far way from the #1 and #6 plug tower install tip that Lloyd gave me???
I should of put a step #4 in, my fault. I'm sorry, Because the crank shaft turns 2 times for each time the cam turns it is possible that following my info you install the distributer 180 out on the exhaust stroke, instead of the compression stroke, if you do the 180 thing you should be OK & you will find out that the rotor will be at the #1 & #6 plug tower.
Sy769 If I remember correctly the flat part of the distributor cap should point towards the driver although it really doesn't matter as long as you aren't putting a strain on the harness. Make sure you seat the distributor all the way to the intake manifold if it won't the oil pump shaft is usually the cause.. Notice the rotor will have to turn as it goes in so it may take a couple times to get it in right. Use a screwdriver if neccesary to turn the oil pump so it will engage the dist. Make sure that the hold down clamp is engaging the distributor when you tighten it. Don't tighten it all the way, just snug it so that you can still turn the distributor with some force when you set the timing.
That is correct the flat part of the distributor must face the driver
SeattleSy#1255 Posted: Fri Feb 04, 2005 1:51 am
Lloyd,
that all makes sense and works great but im not sure about the first part of #3 where is says "Position the rotor between number 1 & 6 spark plug towers. " How do you do this when the internal part of the shaft of the dissy must be lined up with the oil pump to seat fully in there? Also the rotor can only go on one way? Lastly, once its seated in fully, you cant turn it manually unless the engine is being turned as well. I'm sure i'm missing something or am incorrect somewhere, i'v just never dealt with a dissy problem like this.
when you say #1 and #6 towers you are talking on the cap correct?
YOU may have to turn the oil pump drive shaft it with a screw driver.
OK I think I missing something here. Did you tighen the clamp all the way?? you want it tight so it won't turn on it own but loose enough so you can turn it by hand.
SeattleSy#1255
Category 5 Conservative
OK here is the update:
everything is installed and don't worry about that part anymore. here is what i have done.
1) removed #1 plug and manually cranked motor to feel compresson out of hole then lined up the left of the two (looking down) of the timing marks at zero on the timing indicater.
2) installed dissy with oil pump and rotor facing #1 plug tower.
3) started truck and it started right away but running real rough, as if the timing is off.
4) checked timing with timing light (tan wire unplugged) and timing mark on balancer is nowhere to be found no matter which direction i turn the dissy.
results: truck runs harsh with rpm's increasing or decreasing depending on which way i turn the dissy. Again, no timing mark on balancer to be seen either way.
so my question is, what happened? I think where i'm confused or perhaps i'm just missing something is with the dissy install. I understand the flat part should face the driver, no prob. I even tried it facing the passenger. Like some said, i don't think that matters as longs as the wiring harnes can plug in. I'm not understanding the shaft placement/rotor.
I am getting closer I can tell, but i'm missing one big thing I think and i'm guessing its the placement of the rotor.
TYTILIDIE
METH HEAD
Did you get my PM? The 180* thing is one of the most common screw ups people make with distributors.
Mike
SY2455
70's Veteran
Are you checking timing with the the wire unplug in the cab on the pass side. Also check plug wire routing again, I somehow got two wires mix up on my truck once & it would run, but real bad.
How many miles are on your truck Balancer may have spun?
SeattleSy#1255
I went out to check it again.
I went ahead and once again turned it over manually with #1 plug out feeling for compression. Lined up the timing mark. Decided to check rotor under cap, took cap off, sure enough rotor is facing #1 plug tower on cap just as I left it. Decided for the hell of it to take dissy out and 180 degree turn it and it wouldn't even start after reinstall.
I tripled checked the plug wire placement. the numbers are in black on the wire and on the cap, i always do that.
all timing is checked with the passanger side tan wire unplugged..to confirm its the right one, its the one that leads into that ECM bundle correct?
I know the plug wires thing, i'v crossed a few before on accident and your right, truck runs, but like crap...that is usually evident right off the bat.
truck has 69,000 on it. It may have spun, but this whole problem occured when the dissy clamp failed to hold the dissy in place and it jumping out of the oil pump shaft.
On a positive note, there is no clanking or metal sound. Once i get this figured out i'll drain the oil and run a magnet thrue it, but nothing is autible anymore. Of course, i only had it running that one time with the timing far off anyway, but at least nothing apparently welded inself internally.
i'm lost on where to go from here.
SY2455
70's Veteran
So let me get this right.
1. You can't even see the timing mark at all?
2.After you time the truck are you plugging the wire back in so the computer will control timing again?
3. I still think it a timing issue or control module, maybe ECM related,do you have a spare ECM to test with or know someone close by? My ECM went bad at 61,000. Cost me $84 dollars to fix.
skata
sounds like you were in the right ballpark the first time you put the distributor in. if you were 180* off, it wouldn't run.
did you paint your timing mark so that you could see it easier? just take any paint(even whiteout) and paint the groove. then try the timing light. the paint will make the seeing the mark a lot easier.
hth
SeattleSy#1255
Lloyd,
1. I can see the timing mark when I manually turn the motor over and line it up during the compression stroke. Its when I fire it up normally with tan wire unplugged and check timing with a gun that I can't see the mark.
2. Even though I couln't see the mark i plugged it in anyway just to see what would happen. Not much changes.
3. I am convinced its a timing issue. I have another ECM that I was messing with a month back and I have verified that both of the ones I have work perfectly. This all started when I just went to check my timing for the sake of tuning and the dissy disengaged from the oil pump. Other than that, and putting back like you guys say, I don't know what to say or ask now. Its pretty straight forward, i can feel the compression through the hole when i manually turn it over, TDC is found pretty easily as the mark show up when it should on the balancer and all you have to do is line it up (manually). Install dissy which is like sticking a big spark plug in, its pretty easy, had the rotor lined up with #1 plug tower on cap. Tighten dissy down to make sure no movement and truck starts, but no timing mark to been seen via timing light with tan wire unplugged. Truck running bad too, so you can tell its off. Tried loosening bolt and adjusting timing with tan wire unplugged thinking its got to be close, but marker on balancer is so far away that I can't even turn the dissy enough to even see it, let alone line it up. Really wierd.
SeattleSy#1255
ok i'll try the paint/whiteout thing too. I'm up for anything now. BTW: i can see the mark pretty easy anyway, its not full of oil or dirt, but its worth a shot...maybe i'll see something I didn't before?
SY2455
70's Veteran
When you paint the groove use bright color or one of those Speedry #2017 metal marker & wipe off the excess so just the groove is painted.
SeattleSy#1255
anyway, i'd like to confirm what i'v done is correct:
1) Remove dissy
2) Remove plug #1, manually turn motor to feel compression and continue to turn till timing mark (left most one looking down) at TDC.
3) Reinstall dissy with rotor facing #1 plug tower on cap
4) Triple check plug wires on right.
5) Attempt to start truck and runs like crap...check timing with light, tan wire unplugged, timing way off and mark knowhere to be seen.
6) Remove dissy and again find TDC manually
7) Turn rotor 180 degrees and reintall dissy
8) Try to start, no start (didn't think it would but had to try)
9) Remove dissy, again set TDC manually on compression stroke
10) Install dissy with rotor facing #1 plug tower
11) Truck no start
I'm out of ideas!
SY2455
70's Veteran
This doesn't make any sense. have you checked the Ignition module? How old are your plugs & wires? Will the truck smooth out if you turn the distributor clockwise or counterclockwise?
SeattleSy#1255
Wires are brand new, not 1 week old...plugs are the same age. Truck won't smooth out if i turn the dissy, however i only had it running that one time and when i tried to adjust it then, the RPM's would only go up and down, i could turn it low enough to killed itself and fast enough to probalby have the idle rpm's around 1500.
how do i check the ignition module?
Wes
When the harmonic balancer gets old the outer ring that has the timing mark becomes loose and will move around.
SY2455
70's Veteran
When the engine is running at 1500rpm is it smooth or rough running?
When you are doing this is the wire to set timing unplug inside?
When I start my Syclone it will run at 1500rpm for about 20 sec before the computer will bring the idle down to 1100rpm for about 30sec & then it will idle at 900rpm.
If you let it idle at 1500rpm will the computer bring the idle down?
When you turn the distributor to slow it down, you were retarding the timing & when you were speeding the engine up ,you were advancing the timing.
SeattleSy#1255
ok here...i got it running and almost perfect. I once again removed the rotor and it was 180* from where i installed it...found TDC manually and reinstalled it 180...it was still way off, very far, but close enough to start and idle high.
i turned the dissy close to the zero mark but my problem now is that i''m very very close but i can't turn the dissy any more due to the wires not being long enough. Its facing the drivers side.
I'm freaked out to remove it and install it again LOL but i'm going to have to so i have enough room to turn it...
can i just lift the dissy out turn the ignition module while maintaining rotor position, reinstall and time from there?
i'm almost there i think.
to answer your questions Lloyd, it runs smooth, just to fast and never slows. yes tan wire is unplugged.
in terms of the RPM's, yes mine does the same thing for about the same length of time, when its running correctly, but right now, it maintains its RPM no matter where its at.
like i said, we're close, just need to know if i can do the above?
SY2455
70's Veteran
This is going to sound weird, but you need to try it. It sounds like you are 1 tooth off on your distributor. Keep in mind if you turn it the wrong way it will be hard to start. The right way & the truck will start much easier & very close to were you want it.
If you plug the tan wire in, will the computer bring down the idle?
SeattleSy#1255
the way i figued it out was to set it to TDC manually. I would install dissy with rotor pointing toward #1 tower...i'd go to start it and it wouldn't start, just kept turning over. I would then set it to TDC again manually, then remove the cap to see where my rotor was pointing....should be at #1 plug tower right, WRONG...it was always 180* off from there. So i simply pulled the dissy up, turned the rotor 180* and tightned it back down. Fired right up and was good enough to start...got the timing gun out, and went to work...truck idles at 725 and as smooth as could be.
I must have done the above steps literally 10+ times...Half time the it would be 180* off and the other half it would start but be so advanced that I couldn't even turn the dissy enough to set it to zero.
part of the problm is that people say intsall it facing the drivers side, yet that doesn't work much if you need to retard the timing to set it to zero as you can't turn it much more due to the wires on the ignition module being to short. So i after farting around with the correct placement of the IM, i was able to have enough room to work with.
when all was said and done, the cap is facing the drivers side, i just don't think one should start there when installing...at least not on this truck it wouldn't work and I tried over and over 10 plus times.
you are right, it doesn't matter where its facing however one must take into account room to turn the dissy if the timing is off, espically when it was as far off as I was getting, even when it was set to TDC manually.
I appreciate the help much, couldn't have done it without all the advice in this thread. May be a good one to save for people with future problems having the dissy jump out of the oil pump drive shaft.
Thanks Again,
Jeff
